Bookmark
Subscribe
342
"System Bandwidth" & "Performance" Definitions...
guile474a
Hello.  I am hoping someone can help me understand this.
Per some Cisco product documentation, the ASR1K router with an ESP-10 has the following performance characteristics:
"System Bandwidth: 10Gbps"
"Performance: 17mpps"
What is the difference in the definition of "System Bandwidth" and "Performance" above?
Thanks!
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
The system bandwidth is a measure of bandwidth capacity.  10G should be, I believe, the aggregate bandwidth capacity that the ASR's ESP-10 will support.
Mpps is a rating how fast the processor can forward (usually) minimal size Ethernet packets.  Minimum size Ethernet packets require 1.488 Mpps per gig, so 17 Mpps would be good for (about) 11.4 Gbps.  (BTW, where did you see 17 Mpps for an ESP-10?  I've see up to 15 Mpps, which is what I would expect for 10g.)
