r2_restart_timer: timer interdigit outgoing = 24000 ms
icgonzales
I'm getting some error logs in my router C2600 Software (C2600-G4JS-M), Version 12.2(15)T5
Any ideas what is this error logs means? I've already checked this using error decoder and output interpreter but no luck..
Appreciate your kindness to help..thank you.
paolo bevilacqua
Does the call completes when you receive the error ?
I'm seeing this error in both of our HO router and BR router. Routers has the same platform, 2651..which we use as voice gateway connecting to PSTN. There are some reports that calls to PSTN intermittently disconnects thou I'm not very sure if the timestamp are the the same.
Do you think it's IOS / platform issue?
Thank you very much,
Paul
Check disconnects against message occurence.
