Bookmark
Subscribe
973
Trouble shooting of Static NAT
cisco_fun_4899
I have a trouble about Static NAT such as following senario.
Ping command from PC to Router_B's s0 was faild.
C:\>ping 10.1.1.2
Pinging...
Request timed out.
Could you tell me how to troubleshoot this senario?
JAPANESE-ENGLISH TRANSLATION FOR THE FIGURE BELOW
<Static NAT>
Inside Local  -->  Inside Global
172.16.1.2   (trans)  200.1.1.1
                                                              Internet
                                                              Router_B
<Router_A >
Building configuration...
Current configuration : 1011 bytes
version 12.4
hostname Router_A
boot-start-marker
boot-end-marker
enable secret 5 $1$q/hX$ENdPcT6Cr7KZD1elbAYqH/
no aaa new-model
no network-clock-participate slot 1
no network-clock-participate wic 0
ip cef
username cisco password 0 cisco
interface Serial0/0
bandwidth 64
ip address 10.1.1.1 255.255.255.0
ip nat outside
ip virtual-reassembly
no fair-queue
clock rate 64000
interface FastEthernet0/0
ip address 172.16.1.1 255.255.255.0
duplex auto
speed auto
ip http server
no ip http secure-server
ip nat inside source static 172.16.1.2 200.1.1.1
control-plane
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
login local
line vty 5 181
login local
end
<Router_B>
Current configuration : 847 bytes
version 12.4
hostname Router_B
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
interface Serial0/0
ip address 10.1.1.2 255.255.255.0
no fair-queue
ip address 172.18.0.1 255.255.0.0
shutdown
duplex auto
speed auto
ip route 200.1.1.0 255.255.255.0 10.1.1.1
ip http server
control-plane
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
login
end
spremkumar
Level 9
Level 9
Hi Tom
Your NAT scenario is wrong, if its point to point you dont need a NAT over on the 64K link.
You need to make sure that you define proper NAT MAP and the inside/outside NAT interfaces as well.
Also you need to make sure that you have proper routes in place on both the routers.
Do give in more info on what you are trying to simulate or achieve out there.
regds
spremkumar
Level 9
Level 9
Hi Tom
regds
Hi, spremkumar.
Thank you for your reply.
And I'm sorry for my late resposce.
I had cought a cold.
So, this scinario published in someone's blog which contains a lot of missptint is written for a lesson of a Static NAT.
Reading this site, I prepared two routers 2611XM( IOS 12.4 AES). And I configured as above based on the blog's model answers.
●Router_A
version 12.1
service timestamps debug uptime
service timestamps log uptime
hostname Router_A
enable password cisco
interface Serial0
ip nat outside
clockrate 64000
interface Serial1
no ip address
shutdown
ip address 172.16.1.1 255.255.0.0
ip nat inside
speed auto
ip classless
no ip http server
line con 0
transport input none
line aux 0
line vty 0 4
password cisco
login
end
●Router_B
version 11.1
service udp-small-servers
service tcp-small-servers
hostname Router_B
interface Ethernet0
no ip address
shutdown
interface Serial0
no fair-queue
interface Serial1
no ip address
shutdown
ip classless
ip route 200.1.1.0 255.255.255.0 10.1.1.0
logging buffered
line con 0
exec-timeout 0 0
line aux 0
line vty 0 4
password cisco
login
end
Blog saids "You can establish a connection PC to Router_B. Ping now."
If this scenario is wrong, Could you improve this scenario for studying Static NAT?
I'm so sorry... I was so wrong.
I forgot to configure "ip nat inside" at FastEthernet0/0 as shown in my first posting,
> duplex auto
> speed auto
Thank you spremkumar.
