RAM and flash memory type ISR 4321 cisco
Dhikra Marghli
Level 5
Level 5
Hello
i have a router ISR 4321 CISCO have 4 GB RAM AND 4 GB Flash  and i want to add other DRAM and memory Flash !!
1- how i can know kind of RAM that i can add to ISR 4321 cisco  and kind of memory Flash in router !!
what's command or how i can type of RAM in ISR 4321 CISCO !!! ??
cisco ISR4321/K9 (1RU) processor with 1714961K/3071K bytes of memory.
Processor board ID FDO2307A2Y7
Router operating mode: Autonomous
2 Gigabit Ethernet interfaces
4 Voice FXO interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
3125247K bytes of flash memory at bootflash:.
so please , i need from expert Router help me and give me the link or command show type memory !!
thanks in advance
3 Accepted Solutions
here is the datasheet right side last one show the model of your router what RAM you need :
https://www.cisco.com/c/en/us/products/collateral/routers/4000-series-integrated-services-routers-isr/data_sheet-c78-732542.html
here is the video 2 parts replace the RAM, this is model of 4331 but should be the same(or near by).
https://www.youtube.com/watch?v=bk-4jkb6Cwo
BB
hi,
it seems you're running voice on the router (FXO)
you can use the show inventory to check for the RAM installed (PVDM4-32 by default).
you can upgrade/replace the RAM by opening the router chassis. see helpful link below:
http://wannabelab.blogspot.com/2017/01/installing-pvdm4-64-and-nim-2fxs-on.html
it's for a 4331 PVDM4-64 but it shares the same architecture for a 4321 ISR. it only has 1x PVDM slot.
You need single Module DIMM and if you can purchased SSD will be good for your requirement.
BB
7 Replies 7
Dhikra Marghli
Level 5
Level 5
HOW  i can knwo type of memory RAM  and flash  ISR4321 cico that allow me add other CARD RAM  i!!?,
BB
But this doc don't include name ( kind of RAM ) for ISR 4321 cisco !!
i want type of RAM and flash  !!!
hi,
Router#show inventory
INFO: Please use "show license UDI" to get serial number for licensing.
NAME: "Chassis", DESCR: "Cisco ISR4321 Chassis"
PID: ISR4321/K9 , VID: V05 , SN: FDO2307A2Y7
NAME: "Power Supply Module 0", DESCR: "110W AC Power Supply for Cisco ISR 4320"
PID: PWR-4320-AC , VID: , SN:
NAME: "Fan Tray", DESCR: "Cisco ISR4320 Fan Assembly"
PID: ACS-4320-FANASSY , VID: , SN:
NAME: "module 0", DESCR: "Cisco ISR4321 Built-In NIM controller"
PID: ISR4321/K9 , VID: , SN:
NAME: "NIM subslot 0/1", DESCR: "NIM-4FXO Voice Analog Module"
PID: NIM-4FXO , VID: V02 , SN: FOC23035VTT
NAME: "NIM subslot 0/0", DESCR: "Front Panel 2 ports Gigabitethernet Module"
PID: ISR4321-2x1GE , VID: V01 , SN:
NAME: "module R0", DESCR: "Cisco ISR4321 Route Processor"
PID: ISR4321/K9 , VID: V05 , SN: FDO23050QJF
NAME: "module F0", DESCR: "Cisco ISR4321 Forwarding Processor"
for ISR 4321 cisco , !!!
this router does not include PVDM  !!!!??
I need what type of card RAM ( name ) and type of flasm memory that help install in router  !!
i send a picture  about ISR 4321 cisco
i wait a reply for this request
thanks in adv
BB
here is the document : covers both DIMM and FLASH (if you like to increase and have free Slot)
https://www.cisco.com/c/en/us/td/docs/routers/access/4400/hardware/installation/guide4400-4300/C4400_isr/FRUs_Modules.html#65999
BB
