RE: Failover using HSRP or BGP. Which is most suited on edge devices?
tdotvix1982
My question pertains to using either BGP or HSRP at both the internet edge module and or WAN edge module for failover. I CANNOT realistically think of a situation where I would failover between two devices using HSRP at both the internet edge and WAN edge, since in my opinion HSRP is a LAN failover technology by definition and by using BGP we could failover between links on the same router and between devices as well using one of the many attributes provided to us by BGP. At the moment we are using a single router at both internet edge and WAN edge but we intend to redesign the network edge to include failover.
Vick.
Message was edited by: Waqas Raza
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Normally, HSRP is a virtual gateway protocol.  If you're dynamic routing, the routing protocol handles failure without using a virtual gateway.
Joseph W. Doherty
Disclaimer
Posting
