Re: need help with routing
can you draw topology?
Richard Burts
I am puzzled. This is posted as if it were the original post. But the content appears to be a response to some other post. Can you clarify what is the situation?
Rick
this second time happened, I reply and I see my reply as new post.
may be it bug.
ino
yes the original post was from me i am puzzled to
cisco's devices are great but looks like their web interface skills need some work
but the problem is solved
stupid mistake on my side
havent set the gateway on the device properly
