Not able to establish end-end communication
Menon
On eve-ng, I am unable to establish node-to-node communication in my lab (OSPF-BGP). I have five locations using Cisco IOL devices. VPCs are connected to multilayer switches.
In an attempt to ping one location VPC(Virtual PC) to another location VPC, the destination is not reachable. Redistribution of the routers has been completed (OSPF and BGP configured).
Eg config:
#router bgp 100
#redistribute ospf 65111
#router ospf 65111
#redistribute bgp 100 subnets
The OSPF-BGP summary shows that all are up and able to communicate within it. I'll add one location configuration here. It's the same for others as well.
Could I be missing something here? I would greatly appreciate any suggestions you may have.
ISSUE: not able to ping inside interface of multilayer switch and the Vitual PC from outside(central router(cloud))
Thanks.
2 Accepted Solutions
Harold Ritter
Hi @Menon ,
The external ospf routes will not redistribute in BGP by default.
You need to configuring the following on the routers redistributing ospf into bgp.
router bgp 100
redistribute ospf 65111 match internal external 1 external 2
or
you can advertise the edge subnet as an internal route on the multilayer switch as follow:
router ospf 65111
network 10.1.0.0 0.0.0.255 area 0
Hello
@Harold Ritter  beat me to it you need to allow external prefixes as by default only intra-inter area ospf (internal) routes are allowed in bgp redistribution
router ospf 65111
redistribute bgp 100 subnets match internal external
Kind Regards
Paul
Harold Ritter
Hi @Menon ,
router bgp 100
or
router ospf 65111
@Harold Ritter totally right the redistribute connect is learn as external which by default not redistribute into BGP.
some note:-
1- I dont suspect about redistribute connect in first time  because
https://www.cisco.com/c/en/us/support/docs/ip/open-shortest-path-first-ospf/18722-redist-conn.html
this link show that there are two behave of IOS with redistribute connect.
and I really lost here.
anyway, add external to solve this misunderstand.
2-redistirbute with auto-summary is effect the redistribute of OSPF into BGP,
as I mention before you use major same prefix so it can effect.
try no auto-summary under bgp.
Hello
router ospf 65111
Kind Regards
Paul
