Reaching another network without default gateway or route statement.
nathanharper
Background:
In our production environment we have a C9500-40X acting as a layer 3 switch with many VLANs and layer 2 switches connected.  The layer 2 switches range from 3560 at the low end all the way up to 9300 mgig switches.  We have 3750 and 3850 switches as well.  One day I noticed that a 3560 without a default gateway configured and no route statement could ping and telnet outside of its management VLAN.  I configured a 9300 similarly, but it would not ping outside of its management VLAN.
I searched for an answer and found some good info:
https://community.cisco.com/t5/switching/no-default-gateway-but-can-still-ping-other-network/td-p/2995971
https://community.cisco.com/t5/switching/unusual-bahaviour-on-ws-c3560cg-8pc-ip-connectivity-without-ip/m-p/2027329
Peter Paluch from the 2nd link indicates "all Catalyst" switches behave this way.  From my testing the 3560 & 3750 do, but the 3850 & 9300 do not.  In fairness, he wrote that in 2012.
Testing:
I wanted to replicate the behavior in a lab environment with minimal equipment and configuration to eliminate as many variables as possible so others can easily duplicate and verify this.
I took a pair of WS-C3560-24PS switches running version:
Cisco IOS Software, C3560 Software (C3560-IPBASEK9-M), Version 12.2(55)SE12, RELEASE SOFTWARE (fc2)
Compiled Thu 28-Sep-17 02:04 by prod_rel_team
On both switches I issued:
write erase
del vlan.dat
reload
They both came back up with the "Would you like to enter the initial configuration dialog? [yes/no]:" prompt, indicating they are at a default out-of-the-box configuration.
On switch 1 I configured:
enable
configure terminal
vtp mode transparent
hostname Switch-1
user tester privilege 15 secret tester
ip routing
line con 0
login local
logging synchronous
line vty 0 15
login local
logging synchronous
interface vlan 1
ip address 192.168.0.1 255.255.255.0
no shutdown
interface vlan 2
interface FastEthernet 0/1
switchport access vlan 2
spanning-tree portfast
interface FastEthernet 0/24
switchport mode trunk
end
write memory
On Switch 2, I configured:
enable
configure terminal
hostname Switch-2
line con 0
login local
logging synchronous
line vty 0 15
login local
logging synchronous
interface vlan 1
ip address 192.168.0.2 255.255.255.0
no shutdown
end
write memory
Of note, switch 2 has no default-gateway, no interface vlan 2, and no switchport access vlan 2.  The network masks (255.255.255.0) place networks 192.168.0.0 and 192.168.1.0 outside of each other.  Port 24 (trunks) on both switches are connected together and port 1 on both switches are connected to Windows 10 PCs.  Switch 1 is acting as a layer 3 switch, and has proxy-arp enabled by default (not explicitly configured.)
Switch 2 will arp for 192.168.1.1 and receive the MAC address for Switch 1's interface VLAN 1.  Switch 2 can ping and telnet to 192.168.1.1.
PC2 plugged into port 1 on switch 2 with IP address 192.168.0.254 255.255.255.0 and no gateway cannot reach PC1 plugged into port 1 on switch 1 with IP address 192.168.1.254 255.255.255.0 and no gateway:
PING: transmit failed. General failure.
I was curious to see if the PCs would arp for IPs outside of net mask- and they don't.
Adding gateway 192.168.1.1 to PC1 and 192.168.0.1 to PC2, they can ping each other as expected.  Removing the gateways, changing the masks on the PCs to 255.255.0.0, and clearing the arp cache on the PCs and Switches, they can ping each other.  So, like Switch-2, PC-2 can arp across VLANs thanks to proxy arp.
As mentioned above, 3560 & 3750 will arp for addresses outside of configured subnet and ping outside of configured subnet without a default-gateway.  The 3850 and 9300 switches that I tested will not.  I wanted to see if there was something I could do to make the 9300 behave like the 3560.  I turned on ip host-routing and this caused the 9300 to arp for an IP outside of its management subnet and it would add the IP address to its arp table, however it still wouldn't ping outside.  Before turning on ip host-routing it wouldn't arp outside of management subnet.  I used debug arp and debug ip icmp during my testing to verify what was going on.
7 Replies 7
Deepak Kumar
I advised configuring "No IP Proxy-arp" command on L3 SVI or Interfaces on the switch which is working as L3 and clear ARP and MAC table from both switches and try again. It is due to Proxy-ARP.
I hope you will not get ping this time.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
nathanharper
Yes, no ip proxy-arp would stop the L2 switch from receiving the L3 switch MAC address and then a ping would fail.  However, that would not stop the L2 switch from sending arp requests for ip addresses outside of its management subnet.  To stop the L2 switch from making arp requests in the first place, you should configure a default gateway.
That is not the point of my blog post.  I was just demonstrating unexpected behavior, specifically how some L2 switches behave as a proxy client when you wouldn't expect it, and some behave as you would expect.
Deepak Kumar
Not only switch, but Router can also work as Proxy ARP Client.
Deepak Kumar
Deepak Kumar,
gaston.benitez
Hi.
This behavior that you are seeing in your production network. it happens to all vlans? I mean, several vlans with out a DG can ping to others vlans? or it just happens for 2 vlans?
If the issue affects only 2 vlans, please check in your trunks that you may not be doing a native vlan missmatch. Because with it you can end up joining two separete bcasts domains.
BR.
Gaston
Not a native vlan mismatch. See other links I posted in original post.
Joseph W. Doherty
I haven't well read all the posts, but if the issue is related to some device being a IP proxy or not, I recall the default changed somewhere in one of the later IOS versions. I believe proxy used to be on by default (although for years, the standard security recommendation was to disable it), but I believe it's now off by default.
It's not so much that proxy-arp is on, in fact it is on in both cases.
Newer IOS doesn't take advantage of proxy-arp (as a layer 3 client), but
older does- from what I discern.
