Redistribute in OSPF everything learned from a specific BGP Peer
gianluca811
R1 <--BGP----> R2 <---OSPF----> R3
R2 receive routes from R1 trough  BGP. I have to redistribute the same routes to R3 in OSPF. For other reasons the OSPF route must have metric 10000.
I thought to accomplish that with community:
R2
route-map SET-COMMUNITY permit 10
 set community 65001:10000
router bgp 65000
  neighbor IP_R1 remote-as 65001
  neighbor IP_R1 route-map SET-COMMUNITY in
route-map FROM_BGP_TO_OSPF permit 10
 match community 65001:10000
router ospf 100
   redistribute bgp 65000 metric 10000 subnets route-map FROM_BGP_TO_OSPF
but doesn't work. In R2 is see the 10.100.100.0/24 come in EBGP from R1 but I don't see the route in ospf database, obviusly R3 doeasn't see the route as well.
any advice?
9 Replies 9
Pawan Raut
Level 4
Level 4
Can you provide the output for sh ip bgp 10.100.100.0/24 on R2 I want to see if the community string applied on route or not
look so, the community 4290651920 is what I have in configuration
R1#sh ip bgp 10.100.100.0
  Advertised to update-groups:
     13
  65001 65002 65003
    R1_IP from R1_IP (customer_IP)
      Origin incomplete, localpref 100, weight 65000, valid, external, best
      Community: 4290651920
  65001 65002 65003, (received-only)
      Origin incomplete, localpref 100, valid, external
Add this in router config issue will resolved.
ip bgp-community new-format
thanks, I will try this evening
If anyone cares to know how the conversion works:
In the output Pawan requested, the community value is 4290651920. This is converted to binary:
4290651920 = 11111111101111100010011100010000
You take the last 2 bytes (the last 16 numbers of that binary number) and convert it back to decimal:
0010011100010000 = 10000
This number is preceded by the decimal conversion of the first two bytes:
1111111110111110 = 65470
So, the community in new format should be: 65470:10000, which is not what you configured. Either I got it wrong, or another AS (65470)  is sending these community values ?
added the command ip bgp-community new-format but doesn't work as well
As said from Rolf maybe the match community is not supported in redistribustion.
I performed a test with next-hop, and on my virtual lab it's working, I will put this evening the configuration on my network and let's see.
Any further advice is welcome!
this is the script
access-list 10 remark my bgp next hop
access-list 10 permit  BGP-R1_IP_NEIG
   match ip next-hop 10
router ospf 100
just to be sure, do you have 'ip bgp-community new-format' configured on all routers ?
no is not configured
Rolf Fischer
Level 9
Level 9
The match community command requires a community-list:
(config-route-map)#match community ?
  <1-99>     Community-list number (standard)
  <100-500>  Community-list number (expanded)
  WORD       Community-list name
You could try something like this:
ip community-list 1 permit 65001:10000
 match community 1
I'm not sure if the match community condition is supported for routing protocol redistribution:
http://www.cisco.com/c/en/us/support/docs/ip/border-gateway-protocol-bgp/49111-route-map-bestp.html#tables
However, it might be easier and more predictable to use a match ip next-hop or match ip route-source condition instead.
Rolf
