10-25-2016 01:09 PM - edited 03-05-2019 07:21 AM
Both Slots 15 and 31 show as Unknown card when no card is installed front or back . I have tried clearing out the config using "clrallcnf" as well as "clrsrmcnf" (had to install a SRM to run this command) so far nothing has worked to make these slots to show as empty. See below
Unknown.7.PXM.a > dspcd 15
Unknown System Rev: 05.06 Oct. 25, 2016 20:04:44 GMT
MGX8850 Node Alarm: MAJOR
Slot Number 15 Redundant Slot: 16
Front Card Back Card
Inserted Card: UNKNOWN ---
Reserved Card: UnReserved UnReserved
State: Failed Empty
Serial Number: --- ---
Prim SW Rev: --- ---
Sec SW Rev: --- ---
Cur SW Rev: --- ---
Boot FW Rev: --- ---
800-level Rev: B0 ---
800-level Part#: 000-00000-00 ---
CLEI Code: --- ---
Version ID (VID): --- ---
Reset Reason: On Power up
Card Alarm: MINOR
Failed Reason: None
Miscellaneous Information:
10-26-2016 05:14 PM
this is what I see after login.
(1)UNKNOWN SRM CARD TYPE 1, ins=0
Reading novram again
(2)UNKNOWN SRM CARD TYPE 1
(3)UNKNOWN SRM CARD TYPE 1
(4)UNKNOWN SRM CARD TYPE 1
(5)UNKNOWN SRM CARD TYPE 1
(6)UNKNOWN SRM CARD TYPE 1
(7)UNKNOWN SRM CARD TYPE 1
(8)UNKNOWN SRM CARD TYPE 1
(9)UNKNOWN SRM CARD TYPE 1
(10)UNKNOWN SRM CARD TYPE 1
(11)UNKNOWN SRM CARD TYPE 1
(12)UNKNOWN SRM CARD TYPE 1
(13)UNKNOWN SRM CARD TYPE 1
(14)UNKNOWN SRM CARD TYPE 1
(15)UNKNOWN SRM CARD TYPE 1
(16)UNKNOWN SRM CARD TYPE 1
(17)UNKNOWN SRM CARD TYPE 1
(18)UNKNOWN SRM CARD TYPE 1
(19)UNKNOWN SRM CARD TYPE 1
(20)UNKNOWN SRM CARD TYPE 1
(21)UNKNOWN SRM CARD TYPE 1
(1)UNKNOWN SRM CARD TYPE 1, ins=1
I moved this card into slot 8 and the SRM slots for the unknown SRM cards changed to 16 and 32. I have tried every clear config command that I can find and nothing seems to be working on clearing out the SRM slots so they just say empty.
10-27-2016 03:35 PM
I also have a 8950 on site so I plugged this card into it, I did not have to do any changes to the card and it came right up. However instead of Unknown SRM it is saying Unknown XM in slots 9 & 25.
Info on card is:
BAUCAHCAA
800-27202-02 CO *
I compared them to another PXM45/C card that I have that does not have this issue and its info is different.
