Redistribute Mobile
sonny.wigmore
All
Wondering if anyone can help me.
I have a supernet advertisement out of a core site on a network that we manage however, I can't see how this advertising across the MPLS.
There is a route-map but this only advertises statics with a specific tag, This static of 0.0.0.0 points traffic over the customers LAN, but I cant see how this is redistributed, would the "redistribute mobile" command be distributing this, as I see this present in the config.
Thanks for your help.
Ajay Raj
Can you check whether the supernet is available in your Routing Table.
Share me the the Address which is not being advertised and your routing table.
Yes, it is present in the routing table and is redistributing across BGP.
My question is how is this advertised when this isnt redistributed with tag set? I was wondering whether the command redistribute mobile was allowing this to redistribute across the MPLS?
S*   0.0.0.0/0 [1/0] via 10.x.x.x
Please let me know the IP address which you are advertising and how. Is that Default route through BGP
Can I have the config for that?
