Redistribute Static Route
hs08
Hello.
If we have some static routes example we have 10, then how we can redistribute 4 of 10 static route to ospf?
Harold Ritter
Hi @hs08 ,
You can configure the static routes you want redistributed in ospf with a given tag and match on that tag in a route-map used on the "redistribute static" statement as follow:
ip route 192.168.100.0 255.255.255.0 192.168.1.1 tag 999
ip route 192.168.200.0 255.255.255.0 192.168.1.1
router ospf 109
redistribute static route-map static2ospf
route-map static2ospf permit 10
match tag 999
route-map static2ospf deny 20
In this example, only the first static route would be redistributed in ospf.
Harold Ritter
Hi @hs08 ,
router ospf 109
match tag 999
hs08
hi @Harold Ritter
Great !!!, Thank you
hs08
