Routing based on source subnet
jwilder01
Level 2
Level 2
I need to route 2 networks through 4431 out separate interfaces.
I currently have a default route -
ip route 0.0.0.0 0.0.0.0 10.50.0.9 (G0/0/0)
Now, I need VLAN 50 traffic to route to G0/0/2 specifically.
interface GigabitEthernet0/0/0
ip address 10.50.0.10 255.255.255.252
negotiation auto
interface GigabitEthernet0/0/1
description >>Link To SWX<<
mac-address 50f7.22e6.7111
no ip address
negotiation auto
interface GigabitEthernet0/0/1.10
description DATA Vlan
encapsulation dot1Q 10 native
ip address 10.10.32.1 255.255.252.0
no ip unreachables
service-policy input PM_CLASSIFY_IN
interface GigabitEthernet0/0/1.50
description Student VLAN
encapsulation dot1Q 50
ip address dhcp
no ip unreachables
interface GigabitEthernet0/0/1.200
description Voice Vlan
encapsulation dot1Q 200
ip address 10.10.36.1 255.255.255.0
no ip unreachables
interface GigabitEthernet0/0/1.250
encapsulation dot1Q 250
ip address 10.250.32.1 255.255.255.0
interface GigabitEthernet0/0/2
ip address A.A.A.A 255.255.255.248
negotiation auto
balaji.bandi
Not sure what VLAN 50 IP address range :
below example - i use for many places works as expected.
- configure an access list to identify the traffic to be forwarded by PBR
access-list 101 permit ip 192.168.50.0 00.0.255 any  (this is your VLAN IP address range)
- configure a route map to use the acl and set the next hop address
route-map PBR permit 1
match ip address 101
set ip next-hop <next hop address>  (your Gig 0/0/2 next hop IP)
- apply the route map to the interface
interface x/x  ( apply to interface, where required)
ip policy route-map PBR
BB
Hello
So you would possibly first want to make your static default route conditional
The apply some with Policy Base routing (PBR) for your vlan 50 traffic,
However when you do PBR vlan 50 this will ONLY be based on egress traffic, it will have not any bearing on the return path for vlan 50, as such you may incur asymmetric routing, which any ingress traffic for vlan 50 could come in via the primary wan interface.
Example:1 - conditional static default routes
ip sla 1
icmp-echo 8.8.8.8 source-interface gig0/0
timeout 1000
frequency 15
ip sla schedule 1 start now life forever
track 10 rtr1 reachability
access-list 100 permit icmp host 10.50.0.10 host 8.8.8.8 echo
route-map ipsla
match ip address 100
set ip next-hop 10.50.0.9
set interface Null0
ip local policy route-map ipsla
ip route 0.0.0.0 0.0.0.0 gig0/0 10.50.0.9 track 10 name primary link
ip route 0.0.0.0 0.0.0.0 gig0/2 <nexthop ip> 2 name backup link
Example:2 - conditional PBR  (if gig0./2 fails vlan 50 traffic will take the normal routing path specified by routing table
track 11 interface gig0/2 line-protocol
route-map pbr permit 10
set ip next-hop verify-availability <gig0/2 next-hop ip> 1 track 11
Interface GigabitEthernet0/0/1.50
ip policy route-map pbr
Kind Regards
Paul
khorram1998
Level 4
Level 4
To route VLAN 50 traffic through G0/0/2, you can create a static route with the destination network being the VLAN 50 subnet and the next hop being the IP address of G0/0/2.
For example, if the subnet for VLAN 50 is 10.10.32.0/22, you would use the following command:
ip route 10.10.32.0 255.255.252.0 G0/0/2
This tells the router that any traffic destined for the 10.10.32.0/22 subnet should be sent out of the G0/0/2 interface.
Additionally, you can also use a route-map to match the source IP address of the traffic and set the next hop IP address to G0/0/2.
It is also good practice to verify the routing table with command
show ip route
to confirm that the correct routes are in place.
All the best,
AK
