Redistribute Static to OSP
amarula115
I want to distribute only one static route to OSPF.
ip route 10.55.254.0 255.255.255.192 10.80.60.5
My config:
ip prefix-list DMZ201 seq 10 permit 10.55.254.0/26
route-map DMZ201-TO-OSPF permit 10
 match ip address prefix DMZ201
router ospf 200
redistribute static route-map DMZ201-TO-OSPF subnets
Does this config make sense? Any comments
Yes, that is correct configuration.
HTH,
Meheretab
HTH,
Meheretab
amarula115
Thank you for your help.
Would redistribution config be the same or similar if I would like to distribute static route to EIGRP instead of OSPF?
Yes, similar route-map configuration can be used.
When you redistribute Static to EIGRP replace the subnets keyword with metric and metric values.
Example:
router eigrp 123
 redistribute static STATIC-to-EIGRP metric 10000 100 255 1 1500
HTH,
Meheretab
HTH,
Meheretab
