Help with Simple Routing on ASR920
Datacraft
I would like to achive a very simple configuration, but for some reason it's not working for me on the asr920.
Here is the layout I have.
And this is the configuration on the ASR:
interface GigabitEthernet0/0/0
description To_ISP
ip address 165.228.132.26 255.255.255.248
no negotiation auto
interface GigabitEthernet0/0/1
no ip address
negotiation auto
ip default-gateway 165.228.132.25
ip route 0.0.0.0 0.0.0.0 165.228.132.25
When I connect the PC to Gi0/0/1 the port turns green, but I can not ping or do anything out to the internet. The PC will ping its onw IP but nothing else. Not even .26 or .25
I have the Default GW on the PC set to 165.228.132.26 and mask is 255.255.255.248
Am I missing something on the routing part?
Thank you for your help!
Datacraft
I've got it working:
bridge-domain 1
 member GigabitEthernet0/0/0 service-instance 1
 member GigabitEthernet0/0/1 service-instance 1
bridge irb
interface GigabitEthernet0/0/0 no ip address negotiation auto cdp enable service instance 1 ethernet encapsulation untagged interface GigabitEthernet0/0/1 no ip address negotiation auto cdp enable service instance 1 ethernet encapsulation untagged
interface BDI1 ip address 165.228.132.26 255.255.255.248
balaji.bandi
it will not be going to work, because those are routed interface, it only work if you like to make bridge those gi 0/0/0 and gi 0/0/1. (but that will be another requirement).
best example :
You need to configured Gi 0/0/1 with a private IP address, and PC should be in the same IP address range and configure NAT
as per the below document
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/ipaddr_nat/configuration/xe-3s/nat-xe-3s-book/iadnat-addr-consv.html
Note: i can provide the samle config to work, but i always recommend understanding the person who does, so you will not depend on anyone in the future, so you solve the problem easily.
BB
But we do not want them to be NAT-ed. PC Should keep its Public IP Address.
Datacraft
bridge-domain 1
bridge irb
