Redistributing BGP route into OSPF from Azure ExpressRoute
johnsmunoz
BGP/OSPF novice here.  ICND 1 and 2 only went over the basics.
I'm using Microsoft's Azure ExpressRoute with private peering on an ASR1001X with XE 3.16.02.S
show bgp does show my remote routes in Azure.  How do I publish these into my internal OSPF routes so that everyone else knows how to get into the azure private space?
I'm able to see all the other OSPF routes in my network on this ASR so I know I'm a member of OSPF, I just can't figure out how to advertise my azure routes to the rest of my network.
10.0.0.16/32 is the primary network
10.0.0.20/32 is the secondary
172.30.0.0/16 is the remote azure ip space
10.40.0.11 is the ASR
EQX-DA2-ASR#show ip route
Gateway of last resort is 10.40.0.1 to network 0.0.0.0
S* 0.0.0.0/0 [1/0] via 10.40.0.1
10.0.0.0/8 is variably subnetted, 29 subnets, 6 masks
O 10.0.0.0/30 [110/3] via 10.40.0.1, 01:48:33, GigabitEthernet0/0/1
C 10.0.0.16/30 is directly connected, GigabitEthernet0/0/3.1
L 10.0.0.17/32 is directly connected, GigabitEthernet0/0/3.1
C 10.0.0.20/30 is directly connected, GigabitEthernet0/0/4.1
L 10.0.0.21/32 is directly connected, GigabitEthernet0/0/4.1
B 172.30.0.0/16 [20/0] via 10.0.0.18, 2d19h
show bgp
BGP table version is 3, local router ID is 10.40.0.11
Network Next Hop Metric LocPrf Weight Path
*> 10.40.0.0/24 0.0.0.0 0 32768 i
* 172.30.0.0 10.0.0.22 0 12076 i
*> 10.0.0.18 0 12076 i
show run
interface GigabitEthernet0/0/1
ip address 10.40.0.11 255.255.255.0
ip ospf 1 area 0
negotiation auto
interface GigabitEthernet0/0/3
description DA1-CX-PRI-01
no ip address
negotiation auto
interface GigabitEthernet0/0/3.1
description ExpressRoute Primary
encapsulation dot1Q 1000
ip address 10.0.0.17 255.255.255.252
interface GigabitEthernet0/0/4
description DA1-CX-SEC-01
no ip address
negotiation auto
interface GigabitEthernet0/0/4.1
description ExpressRoute Secondary
encapsulation dot1Q 1001
ip address 10.0.0.21 255.255.255.252
router ospf 1
router-id 10.40.0.11
network 172.30.0.0 0.0.255.255 area 0
router bgp 64512
bgp log-neighbor-changes
neighbor 10.0.0.18 remote-as 12076
neighbor 10.0.0.22 remote-as 12076
address-family ipv4
network 10.0.0.30 mask 255.255.255.255
network 10.40.0.0 mask 255.255.255.0
neighbor 10.0.0.18 activate
neighbor 10.0.0.22 activate
exit-address-family
cofee
Level 5
Level 5
This is what you need to redistribute bgp prefixes into ospf:
router ospf 1
redistribute bgp 64512 subnets
hope this helps.
cofee
Level 5
Level 5
router ospf 1
hope this helps.
