Redistribution issue of connected port in ospf
Mohd Nasir
In my network, on a router i have run ospf for wan connectivity and static route for LAN side. I have redistributed static in OSPF.
Now i have connected a PC to the same router and want to redistribute connected in OSPF. When i redistribute connected the LAN side Static switch goes down. Any suggestion or help is apprciated
R1#
router ospf 100
router-id 10.100.6.35
redistribute static metric-type 1 tag 35
network 10.100.6.35 0.0.0.0 area 0
network 10.100.5.60 0.0.0.3 area 0
15 Replies 15
Sorry staitc route for LAN' what you meaning can you more elaborate.
We have conncted  L3 switch from this router on port GE0/0/1 and configured static route
ip route 10.55.1.0 255.255.255.224 10.55.1.134 track 1
Now connected a PC directly on R#1 on port GE /0/0/2 which have to redistribute in ospf 100
this pc connect using same subnet 10.55.1.0
no sir this pc ip is 10.100.5.101 255.255.255.248
are you use IP in PC same as SW subnet ?
No sir
We can not use same subnet ip as in switch . Asper IP schema we have to use different subnet from switch subnet
Try use subnet keyboard with redistribution and check again.
ok sir i will try
Can we have any route-map or metric value variation so that we can only redistribute this connected PC ?
No need when you add subnet keyword it will auto redistribute only connect /32 host IP.
Not working....
My PC ip is 10.100.5.2/29
Router interface ip is 10.100.5.1/29
When i redistribute connected subnets. Other connected switches become not reachable from DC
I Send you message
Martin L
"Static switch goes down" what do u mean ?
Regards, ML
**Please Rate All Helpful Responses **
