how to check flash memory in switch
mohanraj1
I have Cisco 3560 switch. I need to check the flash memory and NVRAM memory. How can i find the information. I'm able to find in show version command but bit confusing, please help me.
Leo Laohoo
Command to check flash memory = dir flash:
Command to check nvram = dir nvram:
Hope this helps.
6 Replies 6
Hi Mohan,
You can check it simply with this command:
show file systems
To find more details about this command with 3560
Please refer to the following link:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_44_se/configuration/guide/swiosfs.html#wp1257201
Wish this be helpful
Leo Laohoo
Hope this helps.
I used the interrupted mode to reset the password of 2950x switch. But after the complete process when I check for sir flash in privilege mode, the reply I get is, Error: loading this flash. But when I reload the flash is intializing in the booting process. Please refer me to some solution.
I have Cisco C6807-XL switch. I need to check the flash memory and NVRAM memory &Physical Memory  How can i find the information.
Hello All, i have the same problem, someone can help us?
show flash:
