Redistribution issue of connected port in ospf
Mohd Nasir
In my network, on a router i have run ospf for wan connectivity and static route for LAN side. I have redistributed static in OSPF.
Now i have connected a PC to the same router and want to redistribute connected in OSPF. When i redistribute connected the LAN side Static switch goes down. Any suggestion or help is apprciated
R1#
router ospf 100
router-id 10.100.6.35
redistribute static metric-type 1 tag 35
network 10.100.6.35 0.0.0.0 area 0
network 10.100.5.60 0.0.0.3 area 0
15 Replies 15
Hello
your routing configuration is incorrect -
you do not need a static route on the L3 switch for the pc subnet residing off the rtr
You only need to advertise a default route towards the L3 switch
Rtr
Router ospf x
Default-information originate always
L3 switch -
just advertise towards the rtr the the interfaces that are performing inter-vlan routing for the lan
int vlan x
Ip ospf x area x
Int vlan y
Ip ospf x area x
Etc…
router ospf x
Kind Regards
Paul
