redistribution
j.tandel
what does redistributing static routes mean? say i have some staic routes configured on the router pointing to my campus network.i have eigrp running on the ATM interface on my router. on this router if i redistribute static routes in eigrp will eigrp learn all my static routes & campus vlans.
amit-singh
Level 8
Level 8
When you do " redistribute static" it will redisribute all the static routes configured on your router to EIGRP and will be marked as EIGRP external" D EX". You can also specify the metric with this command. Also you can use route-map filetrs to filterout certain routes that you dont want to be learned by EIGRP.
http://www.cisco.com/en/US/tech/tk365/technologies_white_paper09186a0080094cb7.shtml
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a008047915d.shtml
HTH, Please rate if it does.
-amit singh
