GRE & IPSEC Tunnel
navneet_78
What is the difference between GRE and IPSEC tunnels? And in which scenarios do we use them?
Also, are the Crypto features only on IPSEC Tunnels?
Appreciate your response
Navneet
amit-singh
Level 8
Level 8
Hi Navneet,
AFAIK GRE tunnels are primarily used on routers. Generic routing encapsulation is what GRE stands for. You can IPSEC over GRE as well which will make it more stronger.Tunneling protocol developed by Cisco that can encapsulate a wide variety of protocol packet types inside IP tunnels, creating a virtual point-to-point link to Cisco routers at remote points over an IP internetwork.
http://www.cisco.com/en/US/tech/tk827/tk369/tk287/tsd_technology_support_sub-protocol_home.html
IPSEC tunnels can be used on any VPN enabled device like Cisco PIX, Concentrator, Routers and other security devices.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios113ed/113t/113t_3/ipsec.htm
HTH,Please rate if ti does.
-amit singh
Hi amit,
That really helped.
Thnx
Navneet
