Redundant ISP failover with PBR
M-Square
I have an issue I am hoping the community might be able to assist with.  I thought posting it here would be good as I am sure others use this type of setup and may benefit from it.
We have a Cisco 891 with dual WAN interfaces using two ISP's.  The main link is the primary internet service while the secondary is only a backup service should the main link experience an outage.  The primary [FA0] is a broadband cable service and the secondary WAN interface [Gi0] is a broadband DHCP based service in standby mode, no active traffic other than monitoring on the backup.
The setup is working with one caveat, when I break the primary service for testing tracking does its job but NAT traffic will not pass, hence the network is down.  The solution is to delete "ip nat inside source route-map NAT0 interface FastEthernet0 overload" and once I do traffic starts to flow through the router again.  The issue of course is that this is not dynamic enough since user intervention is required. I could create an applet to manually handle but this does not seem like it should be the answer.
Below is a snippet of the setup;
track 200 ip sla 200
 delay down 60 up 60
track 300 ip sla 300
 delay down 60 up 60
track 400 ip sla 400
 delay down 60 up 60
track 500 list boolean or
 object 200
 object 300
 object 400
interface FastEthernet0    <-- Primary WAN link (a basic broadband cable service with a static IP)
 description WAN1
 ip address 1.1.1.1 255.255.255.252 [public routable]
 ip nat outside
interface GigabitEthernet8 <-- Backup/standby broadband ISP
description WAN2
 ip address dhcp
 ip nat outside
interface Vlan1
 description LAN
 ip address 10.10.10.254 255.255.255.0
 ip nat inside
ip nat inside source route-map NAT0 interface FastEthernet0 overload    <-- Primary PAT syntax
ip nat inside source route-map NAT1 interface GigabitEthernet8 overload  <--Backup PAT syntax
ip sla 200
 icmp-echo 209.207.110.137
 threshold 1500
 timeout 1500
ip sla schedule 200 life forever start-time now
ip sla 300
 icmp-echo 8.8.8.8
 threshold 1500
 timeout 1500
ip sla schedule 300 life forever start-time now
ip sla 400
 icmp-echo 208.67.222.222
 threshold 1500
 timeout 1500
ip sla schedule 400 life forever start-time now
route-map NAT0 permit 10
 match ip address 140
 set ip next-hop 1.1.1.2  <-- ISP A gateway
route-map NAT1 permit 20
 set ip next-hop x.x.x.x [dhcp default gateway of ISP B]
or
 set ip next-hop dynamic dhcp
access-list 140 permit ip 10.10.10.0 0.0.0.255 any  <-- LAN traffic to be NATed
for this case you should use the match option in the route-map instead of set ip next-hop option, if you don´t the router do NAT with the wrong interface, which is the case, try the next modification.
 match interface FastEthernet0
 macth interface GigabitEthernet8
Hi Pedro,
Thank-you for the suggestion, it seems to have done the trick!
I will be able to fully test in the next few days.
Thanks a million, appreciated.
~M
Pedro made a good suggestion and I believe that when you fully test it will work. Just to be clear on the issue the route map shown in the original post is the kind of route map that is used for PBR which makes decisions about how to forward data packets. But what you need is not a route map for routing but a route map to control NAT. And the important thing in a route map for NAT is that it should have two match statements, one to match the interface and one to match the access list. There is no need for a set statement when the route map is to control NAT.
Rick
Rick
