Regarding loops
ncnaveen_arasu
As a part of troubleshooting we can check the loop for serial interface for WAN connectivity, which was provided by ISP for line testing,
why we can't check loop for ether ports when we terminate a WAN connectivity to these ether ports.
Thanks in advance
Naveen
Richard Burts
Naveen
With a serial connection there are components of the circuit such as the CSU/DSU or the Dmarc or SmartJack etc which make the loopback function possible. These components do not exist in an Ethernet connection. So the loopback test is not possible with an Ethernet connection.
Rick
Rick
Hi Richard,
Thanks for clarifying the doubt.
Naveen
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Other words for what's Rick has posted, Ethernet it a different physical technology from "traditional" serial WAN technologies.
Perhaps the Ethernet test that might be considered most like a loopback test is TDR.  If you're unfamiliar with TDR, you might start with Leo's document, https://supportforums.cisco.com/docs/DOC-18983#comment-9396.
