Regex ".*" and AS number at show ip bgp
syjeon
Hi all.
I'd like to know what it is means regarding regex ' .* ' . To make sure, I wanna do cross-check.
and If I know the specific AS number when I type down as show ip bgp. How can I find out the management ip address of that AS number?
Mohamed Sobair
Level 7
Level 7
The regular expression (.*) means ( any )
However, I am not sure what u exactly means by management IP Address of the neighbor? Could you clarify more..
Mohamed
Jon Marshall
.* means match anything so that will match any AS PATH in the BGP update.
Not sure what you mean with your 2nd question -
sh ip bgp summary  - will show the BGP neighbor IP address
sh ip bgp neighbor - will show the peer BGP router-id
Jon
