Remove BGP no-export community
msizi.mthembu
Frequent Visitor
Frequent Visitor
I have a prefix that I learn from another AS1, which I set a "no-export" community inbound to AS2. AS2 has eBGP sessions to AS3 and AS4. I need to remove/override the "no-export" outbound to AS4 only. I tried the below policy but the prefix is still not being advertised out to AS4. Kindly advise
route-policy POLICY-OUT-1
if destination in ADVERTISE-OUT then
delete community in (no-export)
pass
else
drop
endif
end-policy
Msizi
5 Replies 5
pman
Hi @msizi.mthembu ,
Applying the route-policy outbound on the neighbor to AS3 and AS4 will not work. The updates will not be sent to these neighbors because they are tagged with no-export and would therefore never make it through the route-policy. If you have two routers in AS2 (connected via iBGP), you could apply the route-policy inbound on the second router. This would definitely work.
Hi @Harold Ritter ,
Hope you are doing well.
Is it the same in an MPLS backbone with MP iBGP ?
I mean, if i want to remove "no-export" community only on vrf A and not on vrf B (that are in a same PE) , Does i have to configure an import-map on vrf A with the route-policy shared by @msizi.mthembu ? or I must do it on the PE (that hosts vrf A and vrf B) in inband direction, so on the MP iBGP sesssion with route reflector ?
Hi @nabs ,
The original post dates and your case is different from it. Can you please ask a new question and provided the information specific to you issue?
Hello
Most simplistic way would be to NOT send/advertise community towards AS4, this should then strip any community attribute in the bgp update
Another way would to be apply an community attribute of INTERNET ingress from AS1
Kind Regards
Paul
