removing a route-map from BGP Neighbor
chad.parish
If I wish to remove a
route-map
from a BGP neighbor without removing the neighbor itself does the below work?
router bgp x.x.x.x
neighbor x.x.x.x
no route-map TEST
16 Replies 16
chad.parish
Thanks so much!  If it can great, but if not what is the least intrusive command to clear bgp outbound if each neighbor has a different AS number association? i.e. how can I then just reset outbound BGP adverts for a specific neighbor/AS# in the least intrusive way if route refresh is not an option.
You are so welcome
If each neighbor has it AS then you can clear only AS for this neighbor not need to select all AS.
If I find other solution I will update you.
MHM
