Replace a "Cisco 2801" with a "Cisco ASA 5508-x"
aandewegr
Dear All,
I'm getting a bit stuck with the following configuration and I hope someone can help me.
The configuration in the currently added drawing (See attachment) works properly but the following needs to be adjusted. The router in the top right (2811: xxx.xxx.xxx.xxx) must be replaced with a Cisco ASA 5508-x but I can't get a base ping to 134.xxx.xxx.xxx going wrong!
Who can help me.
Thank you in advance for your effort.
Best Regards,
Remco
7 Replies 7
AndreaTornaghi
Dear,
I think that you are using the wrong next hop on your default route.
I suggest you to change it in 134.222.138.97.
Best Regards
This is an International (Belgium - Netherlands) EVPN connection via multiple ISPs of which I cannot change the configuration. The problem is that the 0.0.0.0 route must go to 134.222.129.41 because the other networks are located there.
Deepak Kumar
Change your default route:
ip route 0.0.0.0 0.0.0.0 134.222.138.97
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Deepak Kumar
Thanks for make some point more clear. Share some output and ASA configuration as
Show route
Deepak Kumar
Deepak Kumar,
HI,
I attached two files
1. Working Config_RTR.txt
2. NOT working Config_ASA.txt
I'm not in the office right now so i can not output "Show route" at this moment.
You are missing NAT configuration as below:
interface FastEthernet0/1.1
description Uplink to Management Network (Vlan 1 - Native)
encapsulation dot1Q 1 native
ip address 192.168.32.1 255.255.255.0
IP nat inside
interface FastEthernet0/1.70
description Uplink to LAN (VLAN 70)
encapsulation dot1Q 70
ip address 192.168.70.1 255.255.255.0
ip helper-address 192.168.70.254
IP nat inside
interface FastEthernet0/0
description Uplink to ISP_BELGIUM
ip address 134.222.138.98 255.255.255.252
ip nat outside
duplex full
speed 100
no shut
IP access-list standard 1
10 permit 192.168.70.0 0.0.0.255
20 permit 192.168.32.0 0.0.0.255
ip nat inside source list 1 interface FastEthernet0/0 overload
Deepak Kumar
Deepak Kumar,
