Replacement FAN Router 3725 / Compatibility with another Cisco 3000 series Routers
Luis Salazar
I need to replace the fan on a Cisco 3725.
Anyone know if the fan of some other equipment is compatible with my 3725?..
Can you tell me which model of router has a fan with similar characteristics that may serve a 3725?.
I leave some specs of my 3725:
System image file is "slot0:c3725-is-mz.123-9.bin"
cisco 3725 (R7000) processor (revision 0.1) with 98304K/32768K bytes of memory.
Processor board ID JMX0729L0QW
R7000 CPU at 240MHz, Implementation 39, Rev 3.3, 256KB L2 Cache
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
2 FastEthernet/IEEE 802.3 interface(s)
1 ATM network interface(s)
DRAM configuration is 64 bits wide with parity disabled.
55K bytes of non-volatile configuration memory.
31744K bytes of ATA System CompactFlash (Read/Write)
31744K bytes of ATA Slot0 CompactFlash (Read/Write)
Thank you very much,
regards,
IJAZDAR
The replacement fan assembly for the Cisco 3725 is eol and eos.
https://www.cisco.com/c/en/us/products/collateral/routers/2600-series-multiservice-platforms/end_of_life_notice_c51-713614.html
ACS-3725-FAN2=
CISCO3725 Fan Qty.2
