Resetting a NIM-4MFT-T1/E1 to factory default
Arron95
Is there a process to reset NIM-4MFT-T1/E1 unit back to its factory default config? I know there probably isn't a simple command, but what I am looking for is a procedure to wipe the configuration as well as any stored data from the unit. The T1/E1 module is currently operating on a ISR4451 router
#NIM-4MFT-T1/E1
#ISR4451
#T1/E1
#Router
#NIM
try:
default interface serial x
no card type {t1 | e1 } slot subslot
no controller {t1 e1 slot /subslot /port
try:
