Avaya IP phone and Cisco switch config
iceman6684
All,
    i am trying to find the best practice for setting up Avaya IP phones on a cisco network. In my experience in the Cisco VOIP world we would use the switchport voice vlan # due to the fact that cisco understands CDP. However, Avaya would use LLDP therefore two things would need to be considered:
1.  does the switch support CDP?
2.   would Switchport voice vlan # propagate to the phone once connected?
any insights would be appreciated it.
thanks,
JP
8 Replies 8
ALIAOF_
Level 6
Level 6
We have Avaya IP phones as well and Cisco 2960 switches.  Here is an example of port configuration:
mls qos map cos-dscp 0 8 16 24 32 46 48 56
mls qos srr-queue output cos-map queue 1 threshold 3 5
mls qos srr-queue output cos-map queue 2 threshold 3 3 6 7
mls qos srr-queue output cos-map queue 3 threshold 3 2 4
mls qos srr-queue output cos-map queue 4 threshold 2 1
mls qos srr-queue output cos-map queue 4 threshold 3 0
mls qos srr-queue output dscp-map queue 1 threshold 3 40 41 42 43 44 45 46 47
mls qos srr-queue output dscp-map queue 2 threshold 3 24 25 26 27 28 29 30 31
mls qos srr-queue output dscp-map queue 2 threshold 3 48 49 50 51 52 53 54 55
mls qos srr-queue output dscp-map queue 2 threshold 3 56 57 58 59 60 61 62 63
mls qos srr-queue output dscp-map queue 3 threshold 3 16 17 18 19 20 21 22 23
mls qos srr-queue output dscp-map queue 3 threshold 3 32 33 34 35 36 37 38 39
mls qos srr-queue output dscp-map queue 4 threshold 1 8
mls qos srr-queue output dscp-map queue 4 threshold 2 9 10 11 12 13 14 15
mls qos srr-queue output dscp-map queue 4 threshold 3 0 1 2 3 4 5 6 7
mls qos queue-set output 1 threshold 1 138 138 92 138
mls qos queue-set output 1 threshold 2 138 138 92 400
mls qos queue-set output 1 threshold 3 36 77 100 318
mls qos queue-set output 1 threshold 4 20 50 67 400
mls qos queue-set output 2 threshold 1 149 149 100 149
mls qos queue-set output 2 threshold 2 118 118 100 235
mls qos queue-set output 2 threshold 3 41 68 100 272
mls qos queue-set output 2 threshold 4 42 72 100 242
mls qos queue-set output 1 buffers 10 10 26 54
mls qos queue-set output 2 buffers 16 6 17 61
mls qos
interface GigabitEthernet1/0/5
switchport access vlan 136
switchport trunk native vlan 136
switchport trunk allowed vlan 136,160
switchport mode dynamic desirable
switchport voice vlan 160
srr-queue bandwidth share 10 10 60 20
queue-set 2
priority-queue out
mls qos trust cos
auto qos voip trust
spanning-tree portfast
User port: for example being connected to interface 1 on the switch. The user population is on VLAN 11
VoiceVlan: VLAN 12
Interface g0/1:  Trunk port to another switch on the network.
Interface f0/1
Switchport mode access
Switchport access vlan 11
switchport voice vlan 12
interface GigabitEthernet0/1
switchport trunk allowed vlan 1,11,12 and etc ( the voice VLAN will also have to be added to the trunk list)
switchport mode trunk
   i would not need the switchport trunk native vlan correct?   Avaya should be using option 176 or 242 and i can create a custom string for the L2Q and L2QVLAN. please advice.
My trunks are configured like this:
interface GigabitEthernet1/0/49
queue-set 2
priority-queue out
mls qos trust cos
auto qos voip trust
end
interface GigabitEthernet1/0/50
queue-set 2
priority-queue out
mls qos trust cos
auto qos voip trust
end
Yes you will have to add the Voice VLAN if you are securing the trunks that way.  And we are using DHCP option 242
CDP is cisco propriety LLDP is an open standard; Avaya Phones and most other IP phone suppliers support LLDP.
Hello. Will this also work with a Cisco 4507R+E?
In you configuration on port 1/0/5, I am assuming is connected on the port that connects to a Avaya phone and a PC via phone port.
looks like you have configured the port as trunk and access at the same time.
queue-set 2
priority-queue out
mls qos trust cos
auto qos voip trust
I think the configuration should look like
Option 1:
int gig x/x/x
switchport mode acccess
switchport access vlan 107
switchport voice vlan 103
no cdp enable
auto qos voip trust
spanning tree port fast
or Option 2
int gig x/x/x
switchport trunk allowed vlan AAA
switchport trunk native vlan XXX
auto qos voip trust
Also can you confirm if my option 2 is valid config between switch to switch.
ALIAOF_
Level 6
Level 6
Oh and certain show CDP neighbor does not show the Avaya IP phones.
VoiceVlan: VLAN 12
Interface f0/1
