Restrict inter-VLAN routing
angristan
Here is my topology:
I have dynamic NAT on ffw.lim.rt01.
VLAN 10's gateway is 10.0.1.1 on ffw.lim.rt01's g0/1.10. VLAN 20's gateway is 10.0.1.17 on ffw.lim.rt01's g0/1.20.
Each VPCS can ping each other.
VPCS can ping 72.145.30.1 thanks to NAT.
I want my VPCS to still access to fai.rt01, but without being able to access each other, which is to say I want to restrict routing between VLAN 10 and VLAN 20.
on ffw.lim.rt01 I have tried this:
access-list 101 deny ip 10.1.1.17 0.0.0.7 10.0.1.1 0.0.0.15
access-list 101 permit ip any any
access-list 102 deny ip 10.0.1.1 0.0.0.15 10.0.1.17 0.0.0.7
access-list 102 permit ip any any
int g0/1.10
ip access-group 102 out
int g0/1.20
ip access-group 101 out
It does not do anything. When I remove "permit ip any any ", it works, except my VPCS can ping 72.145.30.1 anymore.
What am I missing? Is it related to the NAT?
jurczak
Try changing the direction from out to in.
Also the source IP should be 10.0.1.0
7 Replies 7
balaji.bandi
High level  below ACL wrong
access-list 101 deny ip 10.1.1.17 0.0.0.7 10.0.1.1 0.0.0.15   <<-- this should be 10.0.1.17
 can you post the config  of switch and router to look again ?
BB
Thanks, it does not change anything though.
By the way, I updated my message under the ACL ("It does not do anything. When I remove "permit ip any any ", it works, except my VPCS can ping 72.145.30.1 anymore.").
Here are the configs:
ffw.lim.rt01#show running-config
Building configuration...
Current configuration : 3963 bytes
! Last configuration change at 20:51:59 UTC Sat May 11 2019
version 15.6
hostname ffw.lim.rt01
boot-start-marker
boot-end-marker
no aaa new-model
ethernet lmi ce
no process cpu autoprofile hog
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no ip icmp rate-limit unreachable
no ip domain lookup
ip cef
no ipv6 cef
redundancy
no cdp log mismatch duplex
no cdp run
ip tcp synwait-time 5
interface GigabitEthernet0/0
 ip address 72.145.30.2 255.255.255.252
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
 media-type rj45
 no cdp enable
interface GigabitEthernet0/1
 no ip address
 ip nat inside
 duplex auto
 speed auto
 media-type rj45
 no cdp enable
interface GigabitEthernet0/1.10
 encapsulation dot1Q 10
 ip address 10.0.1.1 255.255.255.240
 ip nat inside
 no cdp enable
interface GigabitEthernet0/1.20
 encapsulation dot1Q 20
 ip address 10.0.1.17 255.255.255.248
 ip nat inside
 no cdp enable
interface GigabitEthernet0/2
 no ip address
 shutdown
 duplex auto
 speed auto
 media-type rj45
 no cdp enable
interface GigabitEthernet0/3
 no ip address
 shutdown
 duplex auto
 speed auto
 media-type rj45
 no cdp enable
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface GigabitEthernet0/0 overload
access-list 1 permit 10.0.1.0 0.0.0.15
access-list 1 permit 10.0.1.16 0.0.0.7
access-list 101 deny   ip 10.0.1.16 0.0.0.7 10.0.1.0 0.0.0.15
access-list 102 deny   ip 10.0.1.0 0.0.0.15 10.0.1.16 0.0.0.7
control-plane
banner exec ^C
* IOSv is strictly limited to use for evaluation, demonstration and IOS  *
* education. IOSv is provided as-is and is not supported by Cisco's      *
* Technical Advisory Center. Any use or disclosure, in whole or in part, *
* of the IOSv Software or Documentation to any third party for any       *
* purposes is expressly prohibited except as otherwise authorized by     *
* Cisco in writing.                                                      *
**************************************************************************^C
banner incoming ^C
banner login ^C
line con 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
line aux 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
line vty 0 4
 login
 transport input none
no scheduler allocate
end
ffw.lim.sw01#sh run
*May 11 20:54:18.539: %SYS-5-CONFIG_I: Configured from console by console
Current configuration : 4081 bytes
! Last configuration change at 20:54:18 UTC Sat May 11 2019
version 15.2
service compress-config
hostname ffw.lim.sw01
boot-start-marker
boot-end-marker
no aaa new-model
no ip routing
no ip cef
no ipv6 cef
spanning-tree mode rapid-pvst
vlan internal allocation policy ascending
 switchport trunk allowed vlan 10,20
 switchport mode trunk
 media-type rj45
 negotiation auto
 switchport mode access
 media-type rj45
 negotiation auto
 media-type rj45
 negotiation auto
 media-type rj45
 negotiation auto
interface GigabitEthernet1/0
 switchport access vlan 20
 media-type rj45
 negotiation auto
interface GigabitEthernet1/1
 switchport access vlan 10
 media-type rj45
 negotiation auto
interface GigabitEthernet1/2
 media-type rj45
 negotiation auto
interface GigabitEthernet1/3
 media-type rj45
 negotiation auto
interface GigabitEthernet2/0
 media-type rj45
 negotiation auto
interface GigabitEthernet2/1
 media-type rj45
 negotiation auto
interface GigabitEthernet2/2
 media-type rj45
 negotiation auto
interface GigabitEthernet2/3
 media-type rj45
 negotiation auto
interface GigabitEthernet3/0
 media-type rj45
 negotiation auto
interface GigabitEthernet3/1
 media-type rj45
 negotiation auto
interface GigabitEthernet3/2
 media-type rj45
 negotiation auto
interface GigabitEthernet3/3
 media-type rj45
 negotiation auto
interface Vlan1
 no ip address
 shutdown
interface Vlan10
 no ip address
 no ip route-cache
 shutdown
interface Vlan20
 no ip address
 no ip route-cache
 shutdown
no ip http server
control-plane
banner exec ^C
banner incoming ^C
banner login ^C
line con 0
line aux 0
line vty 0 4
 login
end
Am i missing here some info ? where is your Default Gateway pointing to ?
BB
On the router? I don't have one.
jurczak
Thank you very much.
This works:
int g0/1.10
ip access-group 102 in
int g0/1.20
ip access-group 101 in
I am glad I could help
