restrict VTY access on switch
mdieken011
I have a switch outside our firewall open to the Internet.  It is a newer 3650 switch.  I have an ACL assigned to the vty interface that should restrict management traffic to it.  I found it went into quiet mode because someone was doing a dictionary attack against it.  They attackers were using http authentication built into the switch for management to launch the attack.  I had to turn off http and https server to block them.  My question is why was the ACL not blocking this dictionary attack?
Believe SSH is also considered to use a VTY line.
SSH and telnet are also controlled by transport line under VTY. Not so for HTTP or HTTPS.
6 Replies 6
Joseph W. Doherty
If you're asking why a VTY ACL didn't block HTTP or HTTPS, it's likely because the latter isn't using a VTY line.
I don't quite follow Joseph.  It was blocking ssh traffic but not port 80 and 443 access.
BTW, some other vendors work differently. One that comes to mine, you apply an ACL to the loopback interface, and it controls what goes to the device's management.
its good practice to turn off http/https on switches its unsecure , dont use it on any of our switches globally for that reason
no ip http server
no ip http secure-server
also good practice to use login feature matched to the acl on your vty list for a bit of extra protection
login block-for 300 attempts 10 within 60
login quiet-mode access-class xx
login on-failure log
login on-success log
You can also use MPP feature for mgmt traffic to prevent certain interfaces using it
https://www.cisco.com/c/en/us/td/docs/ios/12_4t/12_4t11/htsecmpp.html
