RIB failure in BGP
M.Sultan
Hi guys
Three questions:
what causes the RIB failure in BGP and what is the solution ?
As underlay protocol for full mesh connectivity we use EIGRP or OSPF, and overlay we use BGP, Does these two protocols yet need to be redistributed manually ?
R1 Loopback int 1
R2 Loopback int 2
R3 Loopback int 3
R4 Loopback int 4
However these above routers has networks in OSPF on physical interfaces but we established neighborship by adding only loopbacks into iBGP in inbound, in this case i only can ping loopback interfaces not the whole networks in neighbours router and vice versa. is this correct method ?
I know using loopback interface has facility of shifting path while a primary path goes down.
15 Replies 15
what point you confuse about ?
