RIP between two Nexus switches
josephqiu
This seems to be a simple situation, but I'm having some trouble with, as NX-OS is somewhat new to me.
Two Nexus 5K switches connected with a direct link, and VLAN 99 is the only VLAN configured on that link (dot1q trunk). I'm trying to peer the two switches using RIPv2, but just don't see they like each other. Configuration is simple:
(on both switches):
router rip test
  address-family ipv4 unicast
   maximum-paths 4
(on N5K-1):
interface Vlan99
  no shutdown
  description VLAN 99
  no ip redirects
  ip address 172.25.182.253/24
  ip router rip test
interface loopback0
  ip address 10.82.82.1/24
  ip router rip test
  ip rip passive-interface
N5K-1# sh ip rip
Process Name "rip-test" VRF "default"
RIP port 520, multicast-group 224.0.0.9
Admin-distance: 120
Updates every 30 sec, expire in 180 sec
Collect garbage in 120 sec
Default-metric: 1
Max-paths: 4
Process is up and running
Interfaces supported by ipv4 RIP :
Vlan99
loopback0
(on N5K-2):
interface Vlan99
no shutdown
description VLAN 99
no ip redirects
ip address 172.25.182.254/24
ip router rip test
interface loopback0
ip address 10.84.84.1/24
ip router rip test
N5K-2# sh ip rip
Admin-distance: 120
Default-metric: 1
Max-paths: 4
Vlan99
loopback0
Confirmed the two switches can ping each other on VLAN 99:
PING 172.25.182.254 (172.25.182.254): 56 data bytes
64 bytes from 172.25.182.254: icmp_seq=0 ttl=254 time=2.998 ms
64 bytes from 172.25.182.254: icmp_seq=1 ttl=254 time=4.908 ms
64 bytes from 172.25.182.254: icmp_seq=2 ttl=254 time=15.944 ms
64 bytes from 172.25.182.254: icmp_seq=3 ttl=254 time=2.877 ms
64 bytes from 172.25.182.254: icmp_seq=4 ttl=254 time=4.973 ms
But I don't see they become RIP neighbors:
N5K-2# sh ip rip nei
RIP Neighbor Information (number of neighbors = 0)
('dead' means more than 300 seconds ago)
Running a debug, I confirmed that both are sending RIP updates to 224.0.0.9.
Any help would be appreciated. It may be something small, or maybe there is restriction on multicast/mgmt plane on the Nexus platform?
Also, there doesn't seem to be an option to configure unicast RIP neighbors on the Nexus. Thanks.
nazimkha
You can try restarting rip :
(config) # restart rip instance-tag
I would also enable debugs and see whats going on
thanks for the response.
Enabled the following debugs:
debug rip input
debug rip output
from switch 1:
N5K-1# 2018 Sep 18 15:39:52.101725 rip: test [15574] periodic update on if Vlan99 for ipv4 af:
2018 Sep 18 15:39:52.101761 rip: test [15574] (default-base) rip_enqueue_output_work on inf Vlan99 for ipv4 af
2018 Sep 18 15:39:52.101788 rip: test [15574] (default-base) Vlan99 for ipv4 af not on output queue yet, enqueue
2018 Sep 18 15:39:52.101833 rip: test [15574] rip_out_wait() passes
2018 Sep 18 15:39:52.101851 rip: test [15574] to dequeue output_queue:
2018 Sep 18 15:39:52.101888 rip: test [15574] (default-base) work on inf Vlan99 for ipv4 af
2018 Sep 18 15:39:52.101913 rip: test [15574] Source is 172.25.182.253 and Dest is 224.0.0.9
2018 Sep 18 15:39:52.101932 rip: test [15574] (default-base) Route 0.0.0.0/0 Metric 3
2018 Sep 18 15:39:52.101953 rip: test [15574] (default-base) Route 10.2.0.0/24 Metric 2
2018 Sep 18 15:39:52.101971 rip: test [15574] (default-base) Route 10.2.2.0/23 Metric 6
2018 Sep 18 15:39:52.101988 rip: test [15574] (default-base) Route 10.2.11.0/24 Metric 2
2018 Sep 18 15:39:52.102004 rip: test [15574] (default-base) Route 10.4.0.0/24 Metric 4
2018 Sep 18 15:39:52.102021 rip: test [15574] (default-base) Route 10.5.5.12/30 Metric 2
2018 Sep 18 15:39:52.102037 rip: test [15574] (default-base) Route 10.5.5.16/30 Metric 4
2018 Sep 18 15:39:52.102054 rip: test [15574] (default-base) Route 10.5.23.0/30 Metric 3
2018 Sep 18 15:39:52.102070 rip: test [15574] (default-base) Route 10.5.23.4/30 Metric 2
2018 Sep 18 15:39:52.102086 rip: test [15574] (default-base) Route 10.5.23.48/30 Metric 2
2018 Sep 18 15:39:52.102103 rip: test [15574] (default-base) Route 10.7.6.0/23 Metric 6
2018 Sep 18 15:39:52.102119 rip: test [15574] (default-base) Route 10.62.19.94/32 Metric 6
2018 Sep 18 15:39:52.102135 rip: test [15574] (default-base) Route 10.82.82.0/24 Metric 1
2018 Sep 18 15:39:52.102151 rip: test [15574] (default-base) Route 10.170.4.0/24 Metric 6
2018 Sep 18 15:39:52.102168 rip: test [15574] (default-base) Route 10.170.6.0/24 Metric 8
2018 Sep 18 15:39:52.102185 rip: test [15574] (default-base) Route 10.176.0.0/24 Metric 3
2018 Sep 18 15:39:52.102201 rip: test [15574] (default-base) Route 55.55.55.55/32 Metric 5
2018 Sep 18 15:39:52.102218 rip: test [15574] (default-base) Route 99.99.99.99/32 Metric 6
2018 Sep 18 15:39:52.102234 rip: test [15574] (default-base) Route 142.224.199.0/24 Metric 2
2018 Sep 18 15:39:52.102251 rip: test [15574] (default-base) Route 142.224.228.85/32 Metric 6
2018 Sep 18 15:39:52.102268 rip: test [15574] (default-base) Route 172.21.64.0/24 Metric 6
2018 Sep 18 15:39:52.102284 rip: test [15574] (default-base) Route 172.25.182.0/24 Metric 1
2018 Sep 18 15:39:52.102300 rip: test [15574] (default-base) Route 172.25.183.0/24 Metric 1
2018 Sep 18 15:39:52.102316 rip: test [15574] (default-base) Route 192.168.77.0/24 Metric 1
2018 Sep 18 15:39:52.102631 rip: test [15574] Outgoing iod is 41
2018 Sep 18 15:39:52.102826 rip: test [15574] Called sendto with 392 bytes sent vs 392 tried.
2018 Sep 18 15:39:52.102873 rip: test [15574] no more to dequeue:
from switch 2:
N5K-2# 2018 Sep 18 15:38:11.524383 rip: test [14577] periodic update on if Vlan99 for ipv4 af:
2018 Sep 18 15:38:11.524494 rip: test [14577] (default-base) rip_enqueue_output_work on inf Vlan99 for ipv4 af
2018 Sep 18 15:38:11.524521 rip: test [14577] (default-base) Vlan99 for ipv4 af not on output queue yet, enqueue
2018 Sep 18 15:38:11.524566 rip: test [14577] rip_out_wait() passes
2018 Sep 18 15:38:11.524584 rip: test [14577] to dequeue output_queue:
2018 Sep 18 15:38:11.524620 rip: test [14577] (default-base) work on inf Vlan99 for ipv4 af
2018 Sep 18 15:38:11.524646 rip: test [14577] Source is 172.25.182.254 and Dest is 224.0.0.9
2018 Sep 18 15:38:11.524666 rip: test [14577] (default-base) Route 10.84.84.0/24 Metric 1
2018 Sep 18 15:38:11.524685 rip: test [14577] (default-base) Route 172.25.182.0/24 Metric 1
2018 Sep 18 15:38:11.524700 rip: test [14577]
2018 Sep 18 15:38:11.524713 rip: test [14577] RIP: Sending hexdump 52 bytes:
2018 Sep 18 15:38:11.524727 rip: test [14577] RIP: rip_dump packet len hexdump 52 bytes:
2018 Sep 18 15:38:11.524746 rip: test [14577] 45c03400 00000000 01110000 ac19b6fe
2018 Sep 18 15:38:11.524764 rip: test [14577] e0000009 02080208 00200000 02020000
2018 Sep 18 15:38:11.524782 rip: test [14577] 00020000 0a545400 ffffff00 00000000
2018 Sep 18 15:38:11.524796 rip: test [14577] 00000001
2018 Sep 18 15:38:11.524822 rip: test [14577] RIP: Sending rip update for rip-test on Vlan99
2018 Sep 18 15:38:11.524841 rip: test [14577] RIP: IP ver 4, total_len 52, ttl 1 source 172.25.182.254 dest 224.0.0.9
2018 Sep 18 15:38:11.524855 rip: test [14577] RIP: UDP sport 520 dport 520 len 32 cksum 0
2018 Sep 18 15:38:11.524869 rip: test [14577] RIP: command=2, version=2, mbz=0, #rte=1
2018 Sep 18 15:38:11.524888 rip: test [14577] RIP: afi=0x2, tag=0, prefix=10.84.84.0 mask=255.255.255.0, nhop=0.0.0.0, metric=1
2018 Sep 18 15:38:11.524901 rip: test [14577]
2018 Sep 18 15:38:11.524915 rip: test [14577] Outgoing iod is 41
2018 Sep 18 15:38:11.525095 rip: test [14577] Called sendto with 52 bytes sent vs 52 tried.
2018 Sep 18 15:38:11.525139 rip: test [14577] no more to dequeue:
2018 Sep 18 15:38:12.514169 rip: test [14577] periodic update on if loopback0 for ipv4 af:
2018 Sep 18 15:38:12.514206 rip: test [14577] (default-base) rip_enqueue_output_work on inf loopback0 for ipv4 af
2018 Sep 18 15:38:12.514233 rip: test [14577] (default-base) loopback0 for ipv4 af not on output queue yet, enqueue
2018 Sep 18 15:38:12.514277 rip: test [14577] rip_out_wait() passes
2018 Sep 18 15:38:12.514295 rip: test [14577] to dequeue output_queue:
2018 Sep 18 15:38:12.514332 rip: test [14577] (default-base) work on inf loopback0 for ipv4 af
2018 Sep 18 15:38:12.514354 rip: test [14577] no more to dequeue:
So they are sending updates on VLAN 99, but the updates are not accepted.  I tested by adding a Catalyst switch to a different VLAN, and pair with switch 1.  It still didn't work until I manually configure "neighor <IP address>" under the Catalyst switch's RIP process.  So it appears to be something related to multicast on the Nexus?
BTW, these Nexus switches have LAN base licenses only "LAN_BASE_SERVICES_PKG".  But it did allow me to enable and configure RIP.
Thanks.
BTW, also restarted RIP. Same problem. Thanks.
