RIP not working
imanco671
Hello Community,
I have RIP enabled on both ASA and L3 switch,
The ASA and L3 are connected to the 192.168.210.0 network.
ASA ethernet - 192.168.210.222
L3 ethernet - 192.168.210.1
I want to share the 192.168.210.0 and the 192.168.220.0 subnets via RIP.
The 192.168.220.0 is my DMZ. This is connected to the ASA and does not connect to the L3. Traffic has to go through the 192.168.210.0 network inorder to reach the DMZ.
So the gateway of the DMZ is 192.168.210.222
This is my RIP output on my L3:
router rip
version 2
redistribute static metric 1
no auto-summary
This is my RIP output on my ASA:
router rip
version 2
no auto-summary
Thanks in Advance!
2 Accepted Solutions
John
Adding network statements is not adding routes, at least not with the IGPs such as RIP/EIGRP/OSPF.
When you add a network statement you are telling the device which interfaces to run RIP on. Once RIP has started to run on those interfaces it will then advertise the subnet + the subnet mask of the interface(s) it is runing on (note only RIPv2 does this not RIPv1). So When you enter
network 192.168.210.0
network 192.168.220.0
on the ASA RIP starts on these interfaces and advertises the subnet/subnet masks out.
But if you don't enable RIP on the L3 switch then those advertisements will just be ignored. So you also need to configure RIP on the L3 switch and add -
now RIP will start on the L3 switch on the 192.168.210.x interface and will receive the advertisements from the ASA. Note that you don't need to add 192.168.220.0 to the L3 switch because the ASA will advertise this to the L3 switch.
Jon
John
The next-hop must be available. You need to be able to get to the SonicWall from the L3 switch so until you connect up the 192.168.200.x network and can ping the SonicWall it won't work.
If you are unsure or want to play safe then you can add the statics back to the ASA and then when everything has been connected up you can remove one static route from the ASA and see if the RIP route shows up instead.
Jon
26 Replies 26
Jon Marshall
John
You need to add network statements ie.
L3 switch
router rip
your config +
ASA
router rip
your config +
you may also want to make the DMZ interface a passive interface on your ASA to stop RIP being run on the DMZ.
Jon
Hi Jon,
What is "your config +"
Correct me if im wrong, but I thought if I add the RIP networks to the ASA then the L3 would automatically learn them?
John
Sorry "your config" just means what you already have under the router rip config.
Not sure what you mean by your 2nd question. If you don't have any network statements then RIP doesn't startup on any interfaces so no RIP updates will be sent between the L3 switch and the ASA. You have to tell RIP which interfaces to run on.
Jon
Jon,
Okay I get you on "your config"
I was thinking that RIP would send the route to the other device using RIP. So if I configured "network 192.168.220.0" on the ASA's RIP, then I would not have to do anything on the L3 switch if RIP was enabled. Sort of syncing of routes between the RIP devices.
I was thinking I could just run the Show Run command on the L3 switch and see that all the routes on the ASA synced together.
So if I add a static route or a route via RIP, then the sync would happen between devices.
My understanding now, is that I have to configure both ASA and L3 with the RIP routes. (adding "network 192.168.210.0 " to both)
John
Jon
Hi Jon,
I have added a command into RIP: " passive-interface DMZ " to my ASA
Will this help?
Since my L3 has many interfaces, should I add those to RIP on the L3?
Here are my interfaces on L3:
192.168.210.1
192.168.202.1
10.10.10.1
192.168.200.1
John
John
Yes passive-interface will simply stop any RIP updates being sent on the DMZ. It shouldn't stop the 192.168.220.0/24 network being advertised to the L3 switch.
You will need to have network statements for every interface that you want RIP to run on and hence advertise to the ASA.
Once you have entered these a "sh route" on the ASA should show all these routes.
Jon
jon,
Sorry to be a pain, but I have added all subnets to my L3 RIP. I did a show route on my ASA and do not see any of the L3 subnets.
John
Okay, no problem.
Can you post the L3 switch config + sh ip route and the ASA config + sh route
Jon
Hi Jon,
First is my ASA config:
ASA Version 8.0(4)
hostname ciscodemo
domain-name ar
enable password U.Tf7HVGT3h encrypted
passwd 2KFQnbNIdIYOU encrypted
names
interface Ethernet0/0
nameif outside
security-level 0
ip address 173.xx.xx.66 255.255.255.224
interface Ethernet0/1
nameif DMZ
security-level 50
ip address 192.168.220.222 255.255.255.0
interface Ethernet0/2
nameif inside
security-level 100
ip address 192.168.210.222 255.255.255.0
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
shutdown
no nameif
no security-level
no ip address
ftp mode passive
clock timezone EST -5
clock summer-time EDT recurring
dns server-group DefaultDNS
domain-name a.com
access-list outside_in extended permit tcp any host 173.xxx.xx.70 eq www
access-list nonat extended permit ip 192.168.210.0 255.255.255.0 192.168.220.0 255.255.255.0
access-list inside_nat0_outbound extended permit ip any 192.168.210.0 255.255.255.0
pager lines 24
mtu outside 1500
mtu DMZ 1500
mtu inside 1500
ip local pool VPNPool 192.168.210.100-192.168.210.150 mask 255.255.255.0
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-615.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
global (DMZ) 1 interface
nat (DMZ) 1 192.168.220.0 255.255.255.0
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 192.168.210.0 255.255.255.0
static (DMZ,outside) 173.xx.xx.70 192.168.220.10 netmask 255.255.255.255
access-group outside_in in interface outside
router rip
version 2
no auto-summary
route outside 0.0.0.0 0.0.0.0 173.xx.xx.65 1
route inside 192.168.3.0 255.255.255.0 192.168.210.1 1
route inside 192.168.5.0 255.255.255.0 192.168.210.1 1
route inside 192.168.98.0 255.255.255.0 192.168.210.1 1
route inside 192.168.102.0 255.255.255.0 192.168.210.1 1
route inside 192.168.103.0 255.255.255.0 192.168.210.1 1
route inside 192.168.104.0 255.255.255.0 192.168.210.1 1
route inside 192.168.105.0 255.255.255.0 192.168.210.1 1
route inside 192.168.110.0 255.255.255.0 192.168.210.1 1
route inside 192.168.111.0 255.255.255.0 192.168.210.1 1
route inside 192.168.112.0 255.255.255.0 192.168.210.1 1
route inside 192.168.113.0 255.255.255.0 192.168.210.1 1
route inside 192.168.150.0 255.255.255.0 192.168.210.1 1
route inside 192.168.151.0 255.255.255.0 192.168.210.1 1
route inside 192.168.154.0 255.255.255.0 192.168.210.1 1
route inside 192.168.155.0 255.255.255.0 192.168.210.1 1
route inside 192.168.214.0 255.255.255.0 192.168.210.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.210.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs group1
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set security-association lifetime seconds 28800
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set security-association lifetime kilobytes 4608000
crypto map outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map outside_map interface outside
crypto map DMZ_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map DMZ_map interface DMZ
crypto isakmp enable outside
crypto isakmp enable DMZ
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
enable outside
svc enable
group-policy DMZAccess internal
group-policy DMZAccess attributes
dns-server value 10.10.10.11 10.10.10.22
vpn-tunnel-protocol IPSec svc
default-domain value arisglobal.com
username syn-client4 password dIb97qfm6shciivc encrypted privilege 0
username syn-client4 attributes
vpn-group-policy DMZAccess
username syn-client5 password dIb97qfm6shciivc encrypted privilege 0
username syn-client5 attributes
username syn-client2 password dIb97qfm6shciivc encrypted privilege 0
username syn-client2 attributes
username syn-client3 password dIb97qfm6shciivc encrypted privilege 0
username syn-client3 attributes
username syn-client1 password dIb97qfm6shciivc encrypted privilege 0
username syn-client1 attributes
tunnel-group DMZAccess type remote-access
tunnel-group DMZAccess general-attributes
address-pool VPNPool
default-group-policy DMZAccess
tunnel-group DMZAccess ipsec-attributes
pre-shared-key *
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
policy-map global_policy
class inspection_default
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect icmp
  inspect ftp
  inspect ipsec-pass-thru
  inspect http
  inspect pptp
service-policy global_policy global
prompt hostname context
Cryptochecksum:b8f3163507733aa9b96ac451b006
: end
ciscodemo#
Here is my L3:
Building configuration...
Current configuration : 3576 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname arouter
enable secret 5 $1$.R0k$6P0VyPHU1HNP1xUfw/
enable password
no aaa new-model
system mtu routing 1500
ip subnet-zero
ip routing
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0/1
switchport access vlan 2
switchport mode access
spanning-tree portfast
interface FastEthernet0/2
switchport access vlan 3
interface FastEthernet0/3
switchport access vlan 4
interface FastEthernet0/4
switchport access vlan 5
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
no ip address
shutdown
interface Vlan2
ip address 10.10.10.1 255.255.255.0
interface Vlan3
ip address 192.168.202.1 255.255.255.0
interface Vlan4
ip address 192.168.200.1 255.255.255.0
interface Vlan5
ip address 192.168.210.1 255.255.255.0
router rip
version 2
network 10.0.0.0
network 192.168.200.0
network 192.168.202.0
no auto-summary
ip classless
ip route 192.168.3.0 255.255.255.0 192.168.200.254
ip route 192.168.5.0 255.255.255.0 192.168.200.254
ip route 192.168.98.0 255.255.255.0 192.168.200.254
ip route 192.168.102.0 255.255.255.0 192.168.200.254
ip route 192.168.103.0 255.255.255.0 192.168.200.254
ip route 192.168.104.0 255.255.255.0 192.168.200.254
ip route 192.168.105.0 255.255.255.0 192.168.200.254
ip route 192.168.110.0 255.255.255.0 192.168.200.254
ip route 192.168.111.0 255.255.255.0 192.168.200.254
ip route 192.168.112.0 255.255.255.0 192.168.200.254
ip route 192.168.113.0 255.255.255.0 192.168.200.254
ip route 192.168.150.0 255.255.255.0 192.168.200.254
ip route 192.168.151.0 255.255.255.0 192.168.200.254
ip route 192.168.154.0 255.255.255.0 192.168.200.254
ip route 192.168.155.0 255.255.255.0 192.168.200.254
ip route 192.168.214.0 255.255.255.0 192.168.200.254
ip route 192.168.220.0 255.255.255.0 192.168.210.222
ip http server
snmp-server community public RO
control-plane
line con 0
line vty 0 4
password
login
line vty 5 15
password
login
end
John
On the L3 switch you have -
you shouldn't need this as the ASA should be advertising this.
That shouldn't be the problem though. Can you -
1) confrim what port the firewall is connected into on the L3 switch
2) post "sh ip route" from the L3 switch and "sh route" from the ASA.
Jon
hi Jon,
I deleted that route, thanks for spotting it.
1. ASA connected to port 0/4 on L3
2.
arouter#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
C    192.168.210.0/24 is directly connected, Vlan5
R    192.168.220.0/24 [120/1] via 192.168.210.222, 00:00:13, Vlan5
John
Okay so the L3 switch "sh ip route" is showing the DMZ subnet being learned via RIP.
What about the ASA ?
Jon
Hi Jon,
ciscodemo(config)# show rip database
192.168.210.0 255.255.255.0    auto-summary
192.168.210.0 255.255.255.0    directly connected, Ethernet0/2
192.168.220.0 255.255.255.0    auto-summary
192.168.220.0 255.255.255.0    directly connected, Ethernet0/1
ciscodemo(config)# show route
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
       E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
       i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
       * - candidate default, U - per-user static route, o - ODR
Gateway of last resort is 173.xx.xxx.65 to network 0.0.0.0
S    192.168.104.0 255.255.255.0 [1/0] via 192.168.210.1, inside
S    192.168.151.0 255.255.255.0 [1/0] via 192.168.210.1, inside
S    192.168.105.0 255.255.255.0 [1/0] via 192.168.210.1, inside
C    192.168.210.0 255.255.255.0 is directly connected, inside
S    192.168.210.100 255.255.255.255 [1/0] via 173.xxx.xx.65, outside
S    192.168.150.0 255.255.255.0 [1/0] via 192.168.210.1, inside
S    192.168.110.0 255.255.255.0 [1/0] via 192.168.210.1, inside
S    192.168.111.0 255.255.255.0 [1/0] via 192.168.210.1, inside
C    173.xx.xx.64 255.255.255.224 is directly connected, outside
S    192.168.214.0 255.255.255.0 [1/0] via 192.168.210.1, inside
S    192.168.98.0 255.255.255.0 [1/0] via 192.168.210.1, inside
S    192.168.5.0 255.255.255.0 [1/0] via 192.168.210.1, inside
S    192.168.113.0 255.255.255.0 [1/0] via 192.168.210.1, inside
S    192.168.112.0 255.255.255.0 [1/0] via 192.168.210.1, inside
S    192.168.102.0 255.255.255.0 [1/0] via 192.168.210.1, inside
C    192.168.220.0 255.255.255.0 is directly connected, DMZ
S    192.168.103.0 255.255.255.0 [1/0] via 192.168.210.1, inside
S    192.168.155.0 255.255.255.0 [1/0] via 192.168.210.1, inside
S    192.168.154.0 255.255.255.0 [1/0] via 192.168.210.1, inside
S    192.168.3.0 255.255.255.0 [1/0] via 192.168.210.1, inside
S*   0.0.0.0 0.0.0.0 [1/0] via 173.xx.xxx.65, outside
