RIP not working
imanco671
Hello Community,
I have RIP enabled on both ASA and L3 switch,
The ASA and L3 are connected to the 192.168.210.0 network.
ASA ethernet - 192.168.210.222
L3 ethernet - 192.168.210.1
I want to share the 192.168.210.0 and the 192.168.220.0 subnets via RIP.
The 192.168.220.0 is my DMZ. This is connected to the ASA and does not connect to the L3. Traffic has to go through the 192.168.210.0 network inorder to reach the DMZ.
So the gateway of the DMZ is 192.168.210.222
This is my RIP output on my L3:
router rip
version 2
redistribute static metric 1
no auto-summary
This is my RIP output on my ASA:
router rip
version 2
no auto-summary
Thanks in Advance!
26 Replies 26
edited for spacing
Jon Marshall
John
These are all static routes. Have you manually entered them all as statics ?
If so they will take precedence over the RIP routes and that's why you are not seeing them as RIP routes. Just as on the L3 switch, until you removed the static route for the DMZ subnet it would not show the RIP route.
Is there a reason you have entered the statics on both the L3 and ASA devices ?
Jon
Hi Jon,
Sorry I do not know what I was doing, this other guy from my other post told me to add them as statics on both devices.
What should I delete? and from which device?
John
John
I am just reading up on that post as we speak.
Edison is very good so i'm trying to follow the logic of why you decided to add them to both devices. If the ASA and the SonicWall were on the same internal subnet i could understand it but they aren't.
Basically which routes are used in the routing table depends on something called AD (Administrative Distance). Static routes have a much better AD than RIP routes so that that is why you don't see the RIP routes in the ASA routing table.
if you wanted to see the SonicWall routes as RIP on the ASA then you would need to remove the static entries on the ASA for the SonicWall subnets. Then the RIP advertisements for the same routes coming from the L3 switch would be installed on the routing table on the ASA.
Let me have a read of that post and see what the logic of it is.
Jon
Edison was a big help, but it was probably me lack of knowledge.... I thought the Sonicwall routes had to be set statically on each device b/c RIP could not transfer them between the two.
I can start removing the static from the ASA....
It would be perfect if RIP can handle the sonicwall tunnel routes (192.168.102.0) from the L3.
John
John
Okay, i've had a read but it's still not clear. Edison suggested what i was suggesting 3 times but i think because you kept questioning he just decided you should go with statics. Not sure really.
Basically the misunderstanding seems to be coming as to where you need statics.
If you are redistributing statics into a dynamic routing protocol you only need to configure the statics on one device and then redistribute that into the dynamic routing protocol on the same device. Every other device simply receives these routes as RIP routes (providing you are exchanging RIP routes)
If you configure statics on both the ASA and the L3 switch for the SonicWall subnets then there is no need for RIP other than to exchange the subnets attached to the ASA and the L3 switch.
If you configure the statics only on the L3 switch and redistribute into RIP then you don't need to configure any statics on the ASA for the SonicWall subnets.
Note on the SonicWall you obviously need statics for any subnets on the L3 switch/ASA that the SonicWall needs to get to.
Either way will work ie. statics everywhere or statics on just the SonicWall and L3 switch and then RIP between the L3 switch and the ASA.
Jon
Hi Jon,
I cleaned up my static routes on my ASA. I dont know what I should do next. Should I go to my L3 and redistribute?
Here is my Show Route from my ASA:
ciscodemo(config)# sh route
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
       i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
       * - candidate default, U - per-user static route, o - ODR
       P - periodic downloaded static route
Gateway of last resort is 173.xxx.xx.65 to network 0.0.0.0
C    192.168.210.0 255.255.255.0 is directly connected, inside
S    192.168.210.100 255.255.255.255 [1/0] via 173.xxx.xx.65, outside
C    173.xxx.xx.64 255.255.255.224 is directly connected, outside
C    192.168.220.0 255.255.255.0 is directly connected, DMZ
S*   0.0.0.0 0.0.0.0 [1/0] via 173.xxx.xx.65, outside
ciscodemo(config)#
John
According to your config you already are redistributing statics on the L3 switch aren't you ?
It can take a bit for the updates to get sent out, can you check "sh route" again on the ASA ?
Jon
Hi Jon,
Still not showing on the ASA.
The 10.10.10.0, 192.168.202.0 and the 192.168.200.0 networks are not connected to my L3 yet, I am still mapping out everything getting ready to cut over.
Does this affect RIP and what it will transfer to the ASA? But it would not explain why the static routes are not transfering to the ASA.
John
John
The next-hop must be available. You need to be able to get to the SonicWall from the L3 switch so until you connect up the 192.168.200.x network and can ping the SonicWall it won't work.
If you are unsure or want to play safe then you can add the statics back to the ASA and then when everything has been connected up you can remove one static route from the ASA and see if the RIP route shows up instead.
Jon
okay thanks jon,
I will have to wait to cut over for the static and the other routes to show.
I will have to wait, at least I can see the DMZ route showing up on my L3 switch.
Thanks again.
John
John
No problem. If you connect it all up and RIP isn't working don't forget you can use statics on the ASA and then troubleshoot..
Jon
