ROM by Critical process cmand fault on rp_0_0 (rc=134) - ASR 1001-x
Hello
We have Cisco ASR1001-x that crashes with this error
I didn't understand exactly what went wrong
what could be the issue here?
7 Replies 7
Leo Laohoo
@Mohammad Abu Helal wrote:
ROM by Critical process cmand fault on rp_0_0 (rc=134) ​
CSCvv86246, CSCvs45089, CSCwd25393, CSCvh86136, CSCwe22066 and many more.
marce1000
  - Use latest advisory software on your ASR : https://software.cisco.com/download/home/284932298/type/282046477/release/Cupertino-17.9.5a
              check if that helps!
 M.
This is what we have and it didn't help
show version | include IOS
Cisco IOS XE Software, Version 17.06.07
Cisco IOS Software [Bengaluru], ASR1000 Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 17.6.7, RELEASE SOFTWARE (fc3)
Cisco IOS-XE software, Copyright (c) 2005-2024 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
  - 17.6.7 , is the latest not the latest advisory , you either have the option of trying 17.9.5a (too) , or since you are working
     with recent releases engage Cisco TAC
 M.
do you have any suggestions for a stable release?
The router will do just routing and CGNAT for 2000 users
The issue started with 17.9.5a and I changed it to 17.6.7 to check if it helps
it looks like both versions have the same issue
        - Then your only option is Cisco support = TAC
 M.
