About the summarization of ABR router and router summurization(OSPF)
yo8-20
Dears,
OSPF diagram show as below
R1 (Area 12 ) ---- R2( Area 0) ---- R3 (Area 0)---- R4(Area 10)
if only R1 loopback 0 interface  advertised to R3  and only ABR router summurize to Area 10 , how to configure
Best Regards,
16 Replies 16
M02@rt37
Hello @yo8-20
"if only R1 loopback 0..." you want to summarize or restrict advertisement ?
Summarize one loopback ? Summarizing only one loopback interface might seem unusual in a such case. Generally, summarization is used to aggregate multiple networks or subnets to reduce the size of the routing table and optimize routing efficiency.
To go further with summarization:
To summarize routes in OSPF, you typically use the `area` command with the `range` option on the router that is the ABR between the areas being summarized. In your scenario, R2 is the ABR between Area 0 and Area 12. Assuming you want to summarize the loopback interfaces of R1 into a single summary route advertised into Area 0, here's how you can do it:
R2 Configuration
router ospf 1
area 10 range <summary_address> <mask>
Replace <summary_address> with the network address to be summarized, and  <mask> with the corresponding subnet mask... For example, if R1's has 3 Loopback interfaces with IP addresses:  192.168.1.1/32, 192.168.1.10/32 and 192.168.1.250/24 and you want to summarize it into a single route ''192.168.1.0/32 to Area 10, you should configure:
router ospf 1
area 10 range 192.168.1.0 255.255.255.0
This configuration on R2 will summarize the routes within the specified range and advertise the summary route into Area 0. R3 will then only see this summarized route to reach R1's Loopback interfaces.
Best regards
I explain wrong message , I want to question if R1 Loopback0 not advertise out of Area 12
how to configure and use prefix-list command , right ?
this LAB for you
two LO one advertise and other not
I use area range NOT-ADVERTISE
Thanks, I want to know command use on   interface below is use to advertise in single area right ?
interface 30/0
ip ospf area 0
hostname R4
boot-start-marker
boot-end-marker
no aaa new-model
no ip icmp rate-limit unreachable
ip cef
no ip domain lookup
no ipv6 cef
ip tcp synwait-time 5
interface Loopback0
ip address 4.4.4.4 255.255.255.255
interface Loopback10
ip address 44.44.44.44 255.255.255.255
interface FastEthernet0/0
no ip address
shutdown
duplex full
interface FastEthernet1/0
no ip address
shutdown
speed auto
duplex auto
interface FastEthernet1/1
ip address 10.0.0.4 255.255.255.0
speed auto
duplex auto
interface FastEthernet2/0
no ip address
shutdown
speed auto
duplex auto
interface FastEthernet2/1
no ip address
shutdown
speed auto
duplex auto
interface FastEthernet3/0
no ip address
shutdown
speed auto
duplex auto
interface FastEthernet3/1
no ip address
shutdown
speed auto
duplex auto
interface FastEthernet4/0
no ip address
shutdown
speed auto
duplex auto
interface FastEthernet4/1
no ip address
shutdown
speed auto
duplex auto
interface FastEthernet5/0
no ip address
shutdown
speed auto
duplex auto
interface FastEthernet5/1
no ip address
shutdown
speed auto
duplex auto
interface FastEthernet6/0
no ip address
shutdown
speed auto
duplex auto
interface FastEthernet6/1
no ip address
shutdown
speed auto
duplex auto
router ospf 100
network 4.4.4.4 0.0.0.0 area 10
network 10.0.0.0 0.0.0.255 area 10
network 44.44.44.44 0.0.0.0 area 10
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
R4#
R1#show run
R1#show running-config
Building configuration...
Current configuration : 1813 bytes
version 15.2
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
ip address 100.0.0.1 255.255.255.0
duplex full
no ip address
shutdown
speed auto
duplex auto
ip address 10.0.0.1 255.255.255.0
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
router ospf 100
area 10 range 44.44.44.44 255.255.255.255 not-advertise
network 100.0.0.0 0.0.0.255 area 0
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
R2#show run
Current configuration : 1756 bytes
version 15.2
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
ip address 100.0.0.2 255.255.255.0
duplex full
no ip address
shutdown
speed auto
duplex auto
ip address 20.0.0.2 255.255.255.0
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
router ospf 100
network 20.0.0.0 0.0.0.255 area 20
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
R3#show run
Current configuration : 1709 bytes
version 15.2
hostname R3
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
no ip address
shutdown
duplex full
no ip address
shutdown
speed auto
duplex auto
ip address 20.0.0.3 255.255.255.0
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
router ospf 100
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
R3#
this all command I use in lab
MHM
Yes @yo8-20
Under router ospf peocess on R3 (ABR) add this command:
area 0 filter-list <name prefix-list> out
Prefix-list deny the IP address and permit 0.0.0.0/0 le 32
Best regards
Hello
M02@rt37solution will work although it will ONLY be filtered in area 10
So If the goal is to filter the prefix from the ospf database then use the solution @MHM Cisco World  suggested or a egress filter-list on R2 (ABR) to deny the area 12 loopback to enter the ospf backbone, both solutions should then filter the prefix from the ospf database
Example: R2
ip prefix-list loop deny 1.1.1.1/32
ip prefix-list loop permit 0.0.0.0/ le 32
router ospf x
area 12 filter-list prefix loop out
Kind Regards
Paul
check below
MHM
Hello @MHM Cisco World
Cannot see why not, you can test it if you like,  I dont the availability to do so.
Filter it egress at the ABR of R2, the prefix should then ONLY be available from it original area (12)
Kind Regards
Paul
sure I will test  and share result here
MHM
Hello @MHM Cisco World ,
area filter lists can be applied on ABR for all types of internal routes including LSA Type 3.
For filtering the most effective is to filter inbound on area 0 on the ABR nodes between source area and area 0.
Filtering outbound on  a specific area has a more limited effect.
Best Regards
Giuseppe
@Giuseppe Larosa @paul driver @yo8-20
I test also filter-list and it also work
Hello
@MHM Cisco World
yeap makes sense, filtering egress at R1(ABR) will remove the prefix from the areas 0 & 20
Kind Regards
Paul
yo8-20
Thanks all for discussion , I understand OSPF summarization , the prefix list and the fliter list
and one more thing I want to know is how to calculate the link cost (bandwidth and cost measure)  of Router between OSPF Router
