08-18-2005 07:16 AM - edited 03-03-2019 10:18 AM
I have a facility that I am in the process of upgrading their LAN. They are moving from a router with a few swiches to a more campus environment. They will be running a 4506 as the core switch connected to a 2600 which is their WAN connecion. We run BGP as part of our MPLS WAN. I have EIGRP configured to support the campus environment but the config does not look right between EIGRP and BGP. My 2600 is providng the gateway between the two. I know I need to inject the EIGRP into BGP to reflect changes as the campus grows without having to maintain static routes. This is the current working config but does not look right. What did I miss? 172.20.x.x will be the campus network and the 10.1.1.x is the WAN.
router eigrp 10
redistribute static
redistribute bgp 65002
network 172.16.0.0
network 172.20.0.0
no auto-summary
router bgp 65002
bgp log-neighbor-changes
network 172.20.1.0 mask 255.255.254.0
network 172.20.4.0 mask 255.255.255.0
redistribute connected metric 100
redistribute static
neighbor 10.1.1.18 remote-as 13979
neighbor 10.1.1.18 soft-reconfiguration inbound
neighbor 10.1.1.18 distribute-list 10 in
no auto-summary
08-18-2005 08:20 AM
Eigrp will not redistribute routes from other sources unless you specify a default-metric.
Let me know if I answered your question,
08-22-2005 08:43 PM
You can try this:
Router1(config)#router eigrp 55
Router1(config-router)#default-metric 1000 100 250 100 1500
08-25-2005 05:40 AM
FYI, if you also need to redistribute iBGP routes:
By default, iBGP redistribution into IGP is disabled. To enable redistribution of iBGP routes into IGP, issue the bgp redistribute-internal command
