route leak between custom vrfs and global VRF
akshaycjoshi
I have 7 interfaces
 2 in VRF 120, 2 in VRF 140 and 2 in VRF 160 and 1 in global VRF
configs:
interface TenGigabitEthernet0/1/0
ip address 100.100.100.1 255.255.255.0
ipv6 address 2012:A2::8/64
interface TenGigabitEthernet0/1/2
vrf forwarding 120
ip address 71.71.71.1 255.255.255.0
ipv6 address 2071:DB7:0:1::2/64
interface TenGigabitEthernet0/1/4
vrf forwarding 120
ip address 81.81.81.1 255.255.255.0
ipv6 address 2081:DB7:0:1::1/64
interface TenGigabitEthernet0/1/3
vrf forwarding 140
ip address 72.72.72.1 255.255.255.0
ipv6 address 2072:DB7:0:1::1/64
interface TenGigabitEthernet0/1/6
vrf forwarding 140
ip address 82.82.82.1 255.255.255.0
ipv6 address 2082:DB7:0:1::1/64
interface TenGigabitEthernet0/1/7
vrf forwarding 160
ip address 83.83.83.1 255.255.255.0
ipv6 address 2083:DB7:0:1::1/64
interface TenGigabitEthernet0/1/1
no vrf forwarding 160
ip address 73.73.73.1 255.255.255.0
ipv6 address 2073:DB7:0:1::1/64
I want each custom VRF to be able to communicate with global VRF and vice versa. However, the VRFs should not be able to speak to each other. How to accomplish it?
EDIT:
Tried the below for VRF 120:
ip route 71.71.71.0 255.255.255.0 TenGigabitEthernet0/1/2
ip route 81.81.81.0 255.255.255.0 TenGigabitEthernet0/1/4
ip route vrf 120 100.100.100.0 255.255.255.0 TenGigabitEthernet0/1/0
% For VPN or topology routes, must specify a next hop IP address if not a point-to-point interface
There is no next hop on the TenGigabitEthernet0/1/0 interface.
20 Replies 20
All the
100.x IPs come under global VRF
I had tried your option but it did not work.
Harold Ritter
Hi @akshaycjoshi ,
You could do it using the import/export process. This requires configuring BGP, so that routes can be imported/exported from and to the global routing table. With newer IOS/IOS-XE versions you can also do it using the
route-replicate
feature, which does not require configuring BGP, but unfortunately it does not yet support IPv6.
You can try the following configuration to export VRF routes to the GRT and import routes from the GRT.
vrf definition 120
 rd 65000:1
 route-target export 65000:1
 route-target import 65000:1
 address-family ipv4
  import ipv4 unicast map all
  export ipv4 unicast map all
 exit-address-family
 address-family ipv6
  import ipv6 unicast map all
  export ipv6 unicast map all
 exit-address-family
vrf definition 140
 rd 65000:2
 route-target export 65000:2
 route-target import 65000:2
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
vrf definition 160
 rd 65000:3
 route-target export 65000:3
 route-target import 65000:3
 address-family ipv4
 exit-address-family
 address-family ipv6
route-map all permit 10
router bgp 65000
 address-family ipv4
  redistribute connected
 exit-address-family
 address-family ipv6
 exit-address-family
 address-family ipv4 vrf 120
 exit-address-family
 address-family ipv6 vrf 120
 exit-address-family
 address-family ipv4 vrf 140
 exit-address-family
 address-family ipv6 vrf 140
 exit-address-family
 address-family ipv4 vrf 160
 exit-address-family
 address-family ipv6 vrf 160
 exit-address-family
Does not work as expected.
VRF 120 for example gets the route for VRF 140 and 160
Router#show ip route vrf 120
Routing Table: 120
71.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
B 71.71.71.0/24
is directly connected, 00:00:09, TenGigabitEthernet0/1/2
L 71.71.71.1/32 is directly connected, TenGigabitEthernet0/1/2
72.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
B 72.72.72.0/24
is directly connected, 00:00:09, TenGigabitEthernet0/1/3
L 72.72.72.1/32 is directly connected, TenGigabitEthernet0/1/3
81.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
B 81.81.81.0/24
is directly connected, 00:00:09, TenGigabitEthernet0/1/4
L 81.81.81.1/32 is directly connected, TenGigabitEthernet0/1/4
82.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
B 82.82.82.0/24
is directly connected, 00:00:09, TenGigabitEthernet0/1/6
L 82.82.82.1/32 is directly connected, TenGigabitEthernet0/1/6
100.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
B 100.100.100.0/24
is directly connected, 00:00:09, TenGigabitEthernet0/1/0
L 100.100.100.1/32 is directly connected, TenGigabitEthernet0/1/0
Hi @akshaycjoshi ,
Can you provide the output for the following command:
sh runn vrf
My bad, I had messed up the commands. Its working fine.
I am glad it worked as expected and thanks for the feedback @akshaycjoshi
