route-map and 'ip policy'command
Just Kennie
Please can any one explain in brief when I need to apply the 'ip policy route-map' command at the interface when doing route-map.
Is it when I am using it for redistribution or packet redirection. Or both.
Hi Kennie,
As pointed by Lejoe "ip policy route-map" is the command used with respect to Policy Based Routing.
PBR has two configuration parts - Creating Policy and applying the policy on the interface.
You create policy using "route-map name" command and apply it on an interface using "ip policy route-map name" command
interface fa 0/0
ip policy route-map xyz
route-map xyz
match ip address 10.10.10.12
set ip next-hop 11.11.11.12
PBR is always matched for inbound traffic on an interface.
lejoe.thomas
Level 3
Level 3
Hi Kennie,
The ip policy route-map command specifies the route-map used for policy based routing and not redistribution.
http://www.cisco.com/en/US/docs/ios/iproute/configuration/guide/irp_ip_prot_indep_ps6350_TSD_Products_Configuration_Guide_Chapter.html#wp1056703
Lejoe
Hi Kennie,
interface fa 0/0
route-map xyz
