Route-map Policy
Martin Cummins
I have the following route-map setup for two internet curcuits:
 Extended IP access list LAN
5 deny ip 10.10.50.0 0.0.0.255 10.0.0.0 0.255.255.255
10 permit ip 10.10.50.0 0.0.0.255 any
route-map INTERNET_FAILOVER permit 10
match ip address LAN
set ip next-hop verify-availability 192.168.10.1 1 track 1
set ip next-hop verify-availability 192.168.20.1 2 track 2
and the following static routes:
ip route 1.1.1.1 255.255.255.255 192.168.20.1
ip route 2.2.2.2 255.255.255.255 192.168.20.1
The problem is when is when i implement 'ip policy route-map INTERNET_FAILOVER' on my Lan interface i cannot ping 1.1.1.1 or 2.2.2.2
Can anyone help as to why i cannt ping these addresses (Everything works if i remove the policy from the interface)?
7 Replies 7
chrihussey
Is the route map configured inbound on the 10.10.50.x interface (just checking)?
The static routes should have no bearing as the first instance of the route map would take over and all packets would be forwarded to the 192.168.10.1 next hop.
Do you have tracking configured?
Can you provide the configs of the three interfaces and the policy map and tracking? It may prove helpful.
Hi, yes the policy was applied to the lan interface.
Tracking is enabled and the ip sla's are up:
Track 1
IP SLA 1 reachability
Reachability is Up
16 changes, last change 1w4d
Delay down 20 secs
Latest operation return code: OK
Latest RTT (millisecs) 23
Tracked by:
Route Map 0
Track 2
IP SLA 2 reachability
Reachability is Up
18 changes, last change 02:14:10
Delay down 20 secs
Latest RTT (millisecs) 24
Tracked by:
Route Map 0
I think the problem may be related to the LAN access-list. If the line 5 deny ip 10.10.50.0 0.0.0.255 10.0.0.0 0.255.255.255 is removed ping is restored. Unfortunatley i need this line so that traffic to the 10.0.0.0/8 is not policy routed.
I agree with your configuration, but just a thought, could you try to add another instance to your route-map:
route-map INTERNET_FAILOVER permit 20
Although the access to the 10.x.x.x network is excluded in the first instance, the additional instance may allow for traffic that is not policy routed to be forwarded.
Deepak Kumar
did you try to add a new route map as:
Any of traffic which is denied in the first statement must route through the 2nd route map.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
The suggestion by Chris to configure another instance in the route map with no match and no set is an approach that frequently is needed when the route map is being used to control what is advertised in a routing protocol. But in PBR there is no need for this kind of null instance. Whatever was denied in the first instance will not be policy routed and will be routing using normal routing logic. No need for the null instance.
Rick
Rick
If I am understanding correctly the ability to ping 1.1.1.1 and 2.2..2 is impacted depending on whether the ACL includes this line
ping to those addresses is broken when the line is in the ACL and ping to those addresses works when the line is removed.
I am quite puzzled about how denying traffic with destination of 10.0.0.0 has any impact on ping to 1.1.1.1 or 2.2.2.2.
I could understand PBR having an impact on reachability of 1.1.1.1 and 2.2.2.2 if the next hop used in PBR was a device with no reachability to those addresses. But that ought to be a problem whether or not you did PBR if the destination was 10.0.0.0
Perhaps if we saw a more complete configuration we might see what is causing this.
Rick
Rick
leevhang
Apologies but just cutting in the discussion.
I am unable to apply route-map policy in CLI(packet Tracer). Basically i am trying to configure a NAT failover using dual ISPs.
Can you help me on this?
