10-18-2006 08:24 AM - edited 03-03-2019 02:23 PM
Do you know how I clear the route-map statistics?
Donagh
10-18-2006 08:36 AM
Hi Donagh
Use the command " Clear route-map counters
HTH,rate if it does
Narayan
10-18-2006 10:52 PM
Thanks for your reply but this command does not work. I am running the following code
c7200-js-mz.121-9.bin
10-19-2006 12:36 AM
May be they introduced this command in the new release.
I am running a 12.3 code and the command is supported.
I was not able to find a document to check when the command was introduced
Narayan
10-19-2006 02:39 AM
Hi Donagh,
why don't you try clearing access-list counters ?
It is essentially an access-list, isn't it ?
Tell us what you think about it and how it helps.
cheers
arav
10-19-2006 03:20 AM
i thought the same but it doesnt work either!!
10-19-2006 06:22 AM
anyone else got any ideas?
