Serial0: attempting to restart
kizitomacgregor
Any ideas as to why i keep getting this message when i do a "debug serial interface" on my 1605 router? The interface will not come up and i want to be sure before i replace it.
pushkar1782
Can you plz paste [sh run ] + debug output so that we can analyze and advise .
thnx
prs
Hi, thx for your response. These are the debug and show run ouputs:
00:24:23: Serial0: attempting to restart
00:24:23: QUICC_SERIAL(0): Reset from 0x200B3F0
00:24:53: Serial0: attempting to restart
00:24:53: QUICC_SERIAL(0): Reset from 0x200B3F0
00:25:23: Serial0: attempting to restart
00:25:23: QUICC_SERIAL(0): Reset from 0x200B3F0
00:25:53: Serial0: attempting to restart
00:25:53: QUICC_SERIAL(0): Reset from 0x200B3F0
00:26:23: Serial0: attempting to restart
00:26:23: QUICC_SERIAL(0): Reset from 0x200B3F0
00:26:53: Serial0: attempting to restart
00:26:53: QUICC_SERIAL(0): Reset from 0x200B3F0
00:27:23: Serial0: attempting to restart
00:27:23: QUICC_SERIAL(0): Reset from 0x200B3F0
00:27:53: Serial0: attempting to restart
00:27:53: QUICC_SERIAL(0): Reset from 0x200B3F0
Current configuration:
version 11.3
service timestamps debug uptime
service timestamps log uptime
hostname R3
enable secret xxx
enable password xx
process-max-time 200
interface Ethernet0
no ip address
shutdown
interface Ethernet1
no ip address
shutdown
interface Serial0
ip address 147.1.x.1 255.x.255.0
encapsulation frame-relay
no ip mroute-cache
bandwidth 2048
no fair-queue
frame-relay map ip 147.x.x.1 120 broadcast
frame-relay map ip 147.x.x.2 121 broadcast
frame-relay map ip 147.x.x.4 123 broadcast
no frame-relay inverse-arp
ip classless
logging buffered 4096 debugging
no logging console
line con 0
exec-timeout 0 0
logging synchronous
line vty 0 4
password xxx
login
end
