Bookmark
Subscribe
330
Route-map
Just Kennie
whats the diff ?
route-map CONNECTED_TO_EIGRP permit 10
match interface Ethernet0/0 Ethernet0/1
and
route-map permit 20
match interface Ethernet0/1
Istvan_Rabai
Level 7
Level 7
Hi Just,
In this context, there is no difference.
Subnets of both E0/0 and E0/1 will be redistributed into EIGRP.
You can use this solution if for example you want to assign different metrics to these connected subnets while redistributing them into EIGRP.
But why don't you put this config into a router and see it for yourself.
Cheers:
Istvan
Istvan_Rabai
Level 7
Level 7
Hi Just,
Cheers:
Istvan
