Route Reflector maintenance without service interuption
Manoj Buddhika
I have question regarding route reflector.
In my MPLS core network ,we have two route reflectors. Two route reflectors
and each PE routers are belonged to a peer group. Route reflectors are Cisco
7301. IOS 12.3.  I have Hardware maintenace on one Routereflector. How can I
do that without interupting the end customer trafic.
Inside the mpls core network OSPF is used as IGP
PE<---->Route reflectors     IBGP
Thank you
Manoj
blau grana
Level 7
Level 7
I assume that RRs are not placed in forwarding paths so no outage should happen if one of RR will go down.
Just to check:
- both RRs are advertising same prefixes?
- both RRs have same clients?
Best Regards
Please rate all helpful posts and close solved questions
Best Regards Please rate all helpful posts and close solved questions
Hello
Also are the RR clients logically AND  physically connected to either RR because if they are just logically connected then when you reload one of the RR routers the RR clients attached to that RR router will be isolated?
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
