Is Policy Routing is not supported in Cisco 3560 Switch?
CSCO11667920
I was trying to apply route-map in Cisco 3560 Switch (C3560-IPBASEK9-M), Version 12.2 (55)SE5, I am able to create route-map but I am not able to apply it on any interface, Kindly reccomend any solution
Hello
Depending on if that IOS supports PBR then make sure you are not trying to apply it to a switchport, as PBR require a routed port to work.
int x/x
no switchport
ip policy route-map xxx
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
      My requirement is
     I have a Cisco 877 router which is configured for internet and I have connected this router in the fa0/23 port of Cisco 3560 switch.
interface FastEthernet0/23
description ******Connected  ADSL RTR*****
switchport access vlan 333
switchport mode access
spanning-tree portfast
interface Vlan333
ip address 172.16.15.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
I need to route the traffic to this router from the 3560 Switch only for a 172.16.15.0/24 subnet so need to set the next hop ip address as the  ip address of the router. I have created a route-map and when i try to apply it using the command
ip policy route-map under the interface vlan 333, it is not taking.
Do i need to change the IOS version??
for Policy Based Routing, you need an IP Services Image and need to change the  SDM Template:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_55_se/configuration/guide/swiprout.html#wp1210866
Hope that helps
Rolf
Hello Krishna,
It is not supported in IP BASE for this platform. However, it is supported in IP SERVICES feature set.
Hope this helps,
Jose.
