Route summarization with range from area 0 to a outside area
hannes1967
Dear friends,
I need to summarize routes from the backbone area to connected areas!
The line in the config of the ABR looks like:
router ospf 2
area 0 range 10.4.0.0 255.255.0.0
area 1 range 10.2.0.0 255.255.0.0
The routing table on a router in area 1 looks like this:
d7-2610xm-TelAnl#sh ip route os
     1.0.0.0/24 is subnetted, 1 subnets
O IA    1.0.0.0 [110/11] via 2.0.0.1, 00:18:31, FastEthernet0/0
     10.0.0.0/32 is subnetted, 2 subnets
O IA    10.4.1.1 [110/12] via 2.0.0.1, 00:18:31, FastEthernet0/0
No summary 10.4.0.0/16
Is summarization only supported from an area to backbone area?
I found some examples in the net from cisco training sites, which show that summary should als work from backbone area to outside!
regards, Hannes
pman
summary example:
vIOS3
interface GigabitEthernet0/0
ip address 1.3.1.3 255.255.255.0
ip ospf 1 area 10
interface Loopback10
ip address 10.10.10.10 255.255.255.0
ip ospf 1 area 0
interface Loopback20
ip address 10.10.20.10 255.255.255.0
ip ospf 1 area 0
router ospf 1
area 0 range 10.10.0.0 255.255.0.0
vIOS1
ip address 1.3.1.1 255.255.255.0
ip ospf 1 area 10
vIOS1#show ip route
         10.0.0.0/16 is subnetted, 1 subnets
O IA       10.10.0.0 [110/2] via 1.3.1.3, 00:12:41, GigabitEthernet0/0
22 Replies 22
 Summarization can be done on the ABR from area 0 to others areas. But, in your case, you have one network only, right?
 The summarization would make sense if you were advertizing for example
10.4.0.0/16
19.5.0.0/16
10.6.0.0/16
10.7.0.0/16
Then the aggragate route would be 10.4.0.0/14.
Hello and thanks!
I added two loopback interfaces in d4
11.4.1.1 255.255.0.0
11.5.1.1 255.255.0.0
Range config in d2:
d2(config-router)#do sh run | i ran
 area 0 range 11.0.0.0 255.0.0.0 not-advertise
Routing table in d7:
d7#sh ip ro 11.0.0.0
Routing entry for 11.0.0.0/16, 2 known subnets
O IA    11.5.0.0 [110/3] via 2.0.0.1, 00:09:13, FastEthernet0/0
O IA    11.4.0.0 [110/3] via 2.0.0.1, 00:09:13, FastEthernet0/0
d7#
d4 has lo 11.4.1.1 and l1 11.5.1.1 (both loopback in area
|    Area 0
d2 ABR
|     Area 1
d7
The l0 and l1 are in area 8 at router d4
d4 ist connected to d2 in area 0
d2 ist connected to d7 in area
d7 always has both networks separate in the routing table!
It works, when I use the
range
command in d4, but in the real network I don’t have responsibility on that ABR!
Thank you very much, I now have a better understanding!
OSPF has limitations with a lot of things. Summary addresses being one of them. You can only summarize on the ABR or ASBR ....and even those commands are different from eachother.
If I  copied your network correctly I was able to summarize on D2 (ABR) into the rest of the area 2 on routes from Area.
-David
