Router 1 has internet access but PC and router 2 do not. Devices can ping each other locally.
danwilko16
Hi, I have internet access with my router.
FE 0/1 is WAN port setup for PPPOE
FE 0/0 is standard port.
Network setup - VDSL modem -- router 1 (1841) switch(2960) -- PC.
Router 2 which can also ping the main router 192.168.1.1
Summary Router 2 and PC do not have internet access while only router 1 does. Which is directly connected to a VDSL modem with PPPOE setup.
Current configuration : 1367 bytes
! Last configuration change at 14:39:54 UTC Mon Jul 20 2020
version 15.1
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip source-route
ip dhcp pool 1
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 1.1.1.1 8.8.8.8 1.0.0.1
ip cef
license udi pid CISCO1841 sn FCZ1043723T
interface FastEthernet0/0
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
interface FastEthernet0/1
no ip address
ip nat outside
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
interface Serial0/0/0
no ip address
shutdown
clock rate 2000000
interface Dialer1
mtu 1492
ip address negotiated
encapsulation ppp
dialer pool 1
dialer-group 1
ppp chap hostname ---removed for security purposes---
ppp chap password ---removed for security purposes---
ip forward-protocol nd
no ip http server
ip nat inside source list 1 interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
access-list 1 permit any
access-list 2 permit 192.168.1.0 0.0.0.255
control-plane
line con 0
line aux 0
line vty 0 4
login
transport input all
scheduler allocate 20000 1000
end
on router 1, add the line marked in bold:
interface Dialer1
mtu 1492
--> ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp chap hostname
ppp chap password
How is Router 2 connected to Router 1 ?
8 Replies 8
Giuseppe Larosa
Hello @danwilko16 ,
a) I would use ACL 2 for global nat statement
no ip nat inside source list 1 interface Dialer1 overload
ip nat inside source list 2 interface Dialer1 overload
b)
Router 2 and the pc needs to point to the LAN interface of router 1
Router 2:
ip route 0.0.0.0 0.0.0.0 192.168.1.1
PC : def gw = 192.168.1.1  DNS = 192.168.1.1
they need it to be sure they send traffic to router 1 LAN when attempting to go to the internet
You can use
show ip nat translation
on router2 to check NAT
Hope to help
Giuseppe
When i use the command show ip nat translation this shows nothing on router 1 and router 2. Router 1s updated file is below. also when i do a traceroute on router 2 it goes to the DG of 192.168.1.1 then just ends it cant get off the DGW .
S* 0.0.0.0/0 [1/0] via 192.168.1.1
This is the only route i have in router 2 with its one interface that uses DHCP with an ip address of 192.168.1.2
hostname Router 1
boot-start-marker
boot-end-marker
no aaa new-model
ip source-route
ip dhcp pool 1
dns-server 192.168.1.1
ip cef
no ip domain lookup
ip nat inside
duplex auto
speed auto
no ip address
ip nat outside
duplex auto
speed auto
no ip address
shutdown
clock rate 2000000
interface Dialer1
mtu 1492
encapsulation ppp
dialer pool 1
dialer-group 1
ppp chap hostname
ppp chap password
no ip http server
access-list 1 permit 192.168.1.0 0.0.0.255
interface Dialer1
mtu 1492
--> ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp chap hostname
ppp chap password
Awesome! That has solved the issue, this was the first time i've set up hardware.
What about Router 2, is that working now as well ?
Yes it is. It looks like the command was on the wrong interface.
balaji.bandi
High level looks good
try below commands and let me know :
no access-list 1 permit any
no access-list 2 permit 192.168.1.0 0.0.0.255
access-list 1 permit ip 192.168.1.0 0.0.0.255 any
BB
how is Router 2 connected to your network ? Post a schematic drawing of your topology, as well as the configuration of Router 2.
