Router 1721 booting problem
hraghav
Recently router 1721 was purchased. After configuring, saving to NVRAM (wr mem) and restarting (reload) the router is starting with factory default. But the NVRAM contains the configuration (show configurations). IOS is 12.3(7)t1.
Router has one fast ethernet and one WAN interface (WIC-1T). Pl let me know how to solve this problem.
spremkumar
Level 9
Level 9
Hi Raghav
First thing comes to my mind is the register settings which i feel is 0X2142 which has to be set rite to 0X2102.
The former one is used for recovering lost passwords.
Restore the startup config by copying the same to running config and change the register value using the global command config-register 0X2102 and save the config.
regds
spremkumar
Level 9
Level 9
Hi Raghav
regds
Thank you very much it resolved the problem.
I was struggling with this problem for more than 3 days. It got resolved.
Thanks.
Raghavan.
